  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Inverter help
Mon Aug 13 2007, 06:33PM
I'm surprised that it works as drawn!
I'm suprised that the 74LS73 high output current is enough to drive the transistors.
(by the way, to answer your earlier question, LS stands for "low power schottky",
like normal TTL but faster due to internal schottky diodes preventing the internal transistors from saturating)
Add a 330 ohm to 2.2 kOhm resistor from each of the Q and /Q outputs to +5V
you will get much a better output waveform.
Mon Aug 13 2007, 06:44PM
Hey, I'm really sorry for this. I could have done better than misreading the schematic and then moaning about it. The circuit will work as it was (with filtered supply, surely amazed ), although with probably not much efficiency and practical purpose.
One of problems with 3055's is their heavily variable Hfe. It can be as low as 5, and this must be taken care of.
Munkey
Mon Aug 13 2007, 07:26PM
Munkey Registered Member #588 Joined: Sat Mar 17 2007, 11:06AM
Marko wrote ...
I'm amazed it worked to, not many things turn out to work after I have designed them, I tend to break more than make! tongue
Changing gain... Hmmm what about feeding in a constant current pulse in each individual 3055?
Sulaiman wrote ...
Opps it is a SN74CH12N Flip-flop, not 74LS73.
Ive added a 330R in series with the 2K2 variable and it did nothing... and I added one on the Q and /Q FF outputs and it raised the wavefrom up, is this good? So it is biasing the driver transistors?
Mon Aug 13 2007, 09:48PM
To answer your question
"Ive added a 330R in series with the 2K2 variable and it did nothing... " (That's what I'd expect - no change)
"and I added one on the Q and /Q FF outputs and it raised the wavefrom up, is this good?
So it is biasing the driver transistors?" (Yes that's good, the increased bias will allow higher current output)
I'm glad you're getting there.
Munkey
Tue Aug 14 2007, 08:09AM
I'm getting there, slowly.
I blew up another flip-flop, It was giving out +5V on the /Q pin. After this one I don't have any left frown
It may not be the best inverter, but do you think it is ready to put it in a nice neat box?
