  • Guests: 42
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Making a Geiger-Müller Counter
Sat Feb 09 2008, 01:42PM
Leslie kindly donated some radium watch hands so I could test my counter. The count rate at different distances corresponds to what Leslie got with his SBM-21 counter, so my homemade version definitely works!
226 Watch Hands
Sat Feb 09 2008, 02:21PM
Uzzors wrote ...
226 Watch Hands
There are plenty of thorium and uranium minerals to look for in Norway!
Sat Feb 09 2008, 05:31PM
Good call, I had forgotten about that. Next time I'm out hiking I'll bring the counter with me and see if I find anything.
plazmatron
Sun Feb 10 2008, 07:03PM
Good Idea!
I went up to Tyndrum mine in Scotland yeaterday, to prospect for Uranium, with my CD-V700. I didnt get lucky, I`m afraid, but the background count up there is impessively high! I`m thinking Cornwall next, since the Uraninite deposits at Tyndrum are very minor, but it will be a thousand mile round trip! sad
Sun Feb 10 2008, 08:01PM
plazmatron wrote ...
Good Idea!
I visited the spoil heaps of several ruined Cornish tin mines once noted for their pitchblende, without discovering anything very interesting, but the beach near St Austell produced some remarkable treasures in just a few minutes.
The main part of the beach is covered with sand, but at the back of the beach a natural bank of pebbles has formed. In this I found water-worn pitchblende pebbles so active that I could detect them at two or three metres. The most active of these conspicuously heavy, chocolate-brown pebbles measured 150uSv/hr @ 10cm, and the least active, which was a much lighter brown, about 20uSv/hr.
I talked to local folk [who knew nothing of the pitchblende] and it seems that at times of winter storms and tides, the sand may be swept from the beach altogether, exposing the country rock beneath. Here I would expect to find a wealth of pitchblende, as such dense but smooth pebbles would naturally find their way to the bottom layer immediately above the bed rock, and be last to be swept away. [ i.e. gravimetric separation]
These rich ores perhaps come from the same load worked on by the long defunct British and General Radium Corporation Ltd mine at South Terras, which lay between St. Stephen and the Grampound Road somewhat inland from St Austell.
You can see on the Google Maps Satellite image the uranium mill chimney sticking up out of the trees of a small wood which has now overgrown the whole site.
I also found this which may interest Leslie:
"In Scotland the most important uranium mineralization occurs in three locations:-
1. in low-grade, phosphatic and carbonaceous horizons in the Middle Devonian lacustrine basin of the Orkneys and Caithness;
2. in Devonian arkosic breccias marginal to the Caledonian Helmsdale granite at Ousdale on the east coast of Caithness;
3. in veins marginal to the Caledonian Criffel granodiorite at Dalbeattie.
The Ousdale area was drilled in the early 1970s on a 130 m square grid with 41 percussion holes to depths of 80 m. The maximum value found was 850 ppm U within a 15 m intersection.
Uranium-lead mineralization occurs in a fault breccia in Devonian sediments at Mill of Cairston, near Stromness on Orkney. The fault was drilled by the BGS and a mining company consortium in 1971–1972 when maximum values of 1000 ppm U were found, together with 5.5% lead."
[Source: British Geological Survey, Mineral Profile, Uranium, March 2007]
plazmatron
Wed Feb 13 2008, 03:51AM
Thanks! I just got the pdf!
Dalbeattie looks parkticularly promising, and is only 200 miles away or so. There is a reference to Pitchblende veins being found in the cliffs there.
Leslie
Wed Feb 13 2008, 10:26AM
There's always a good chance of finding fallen material at the foot of a cliff - if you can get to it, and it isn't under water at low tide.
Wed Feb 13 2008, 10:29AM
Conundrum wrote ...
Hmm. MacGyver would be impressed :)
I still want to know why someone hasn't devised a servo-like arrangement that simply moves a variable thickness lead/copper alloy on a pivot across the sensor. As the radiation flux increases it rotates to keep the sensor from saturating then applies a scaling factor.
/me scuttles off to try this.
EDIT:- I have three SBM 20's. One removed from my counter erroneously, the other two are in my counter. Does anyone have a use for these?
i also have some 180V zeners here that might be useful for regulating the supply.
-A
Wed Feb 13 2008, 12:05PM
There is a detailed account of the rich uranium mineralization in the cliff top near Needle's Eye, Colvend, Dalbeattie, in MINERALOGICAL MAGAZINE, JUNE 1990, VOL. 54, PP. 129--131.
plazmatron
Wed Feb 13 2008, 09:28PM
Wow! that site is looking more and more delicious! Thanks Harry!
I`m thinking of taking a wee field trip!
According to auto route, I can make it there in about 3 hours, so If I set off early enough it can be a day out! cheesey
I have been dying to have a crack at extracting Uranium for some time!
