  • Guests: 47
minor explosion
ragnar
Thu Mar 02 2006, 12:24PM Print
well, thanks to my new 20MHz scope, I just got "first light" which was nice... and also the first chunk of MOSFET to ever get this |-----| close to my eye.
I suspect the gate was overvolted - the cross-sectional area of my feedback winding is seemingly not small enough =P
Hit 6.5MHz, was able to draw plenty of arcs... upped the primary/input voltage to 48V, managed to coax it to breakout of its own accord, but then the left half of one of my FETs urgently desired to be very far away from that hot metal die. Oops. =)
Thu Mar 02 2006, 01:32PM
Now when you say |-----| close, do you mean |-----| close at 1024x768 on a 16in monitor?
Glad to hear you are ok but it sounds like your coil is/was comeing along well. Keep it up! (and wear goggles)
Self Defenestrate
Thu Mar 02 2006, 02:38PM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
Cover up all your components with a few standoff's and a towel during testing, keeps those bits of mosfet shrapnel contained. Got any pics?
Marko
Thu Mar 02 2006, 02:58PM
High-frequency royer coils obivously dont like high voltages.
Feedback overvolts gate and there is obivously not too much help.
You can hack bigger arc using just single diode halfwave rectifier and no filter caps, and here I hit the limit - 36V halfwave rectified input, tried to filter it with cap and blew mosfet too.
Feedback overvolts gates and zener causes trouble (probably by its capacitance) if connected across agte.
This is for 2 mhz mini coil now I intend something bigger and try to beat 10 mhz... confused smile
Topic is somewhere down, 'mini monster SSTC) smile where pics can be seen.
Arc is incredibly hot for size of coil and just few tens of watts.
It actually loses lots of power at secondary (skin-effect) heating it up, mosfets do not dissipate lot of power and can be tortured unlimited time on small heatsinks.
Coil jamms internet connection, all forms of radio, TV, telephone... so I cant run it for much confused
robert
Thu Mar 02 2006, 04:16PM
robert Registered Member #188 Joined: Thu Feb 16 2006, 05:18PM
Other things can explode too (just happened to me before):
I had a 300w halogen lamp (cheap thing, 10 euro or so) and had it on for maybe 15min for taking some photos with good light, and when i just was in another room i heraed a very loud explosion and when i looked in, the lamp was exploded ant there were hot glass fragments everywhere and even burned a hole in some plastic thing 5meters away.
1141316157 188 FT2876 Lamp Fail
Thu Mar 02 2006, 06:02PM
wrote ...
Hopefully you were wearing safety goggles.
ragnar
Fri Mar 03 2006, 05:40AM
EVR, believe it or not, in my ignorance, I'd chosen not to wake the household up by going outside to the garage where I'd left them. It would have been even worse if I'd needed an ambulance at 11pm to pull warm semiconductor shrapnel out of my eye.
The goggles start today.
Learn from my mistakes, guys. :)
Fri Mar 03 2006, 06:13AM
Any time I am around high voltage or high rpm machinery I wear goggles. It just isn't worth it....
I am curious, how many people wear goggles when working with high voltage and capacitors or just high voltage?
Fri Mar 03 2006, 06:16AM
After discharging my first MWO cap I started wearing goggles aroudn all my HV stuff. (other then the van de graff) The cap discharge didnt hit me with anythign but the bang gave me enough of an idea about what could happen.
Fri Mar 03 2006, 07:01AM
I definantly wear them when using power tools (mainly dremel), and when I am first pwering up something I am not sure about... Other than that I do not have enough things explode that I really worry about it... (no sstc's yet)
