  • Guests: 54
arnsfelt (46)
jaysun92 (33)
12/02 Hax (40)
12/02 PhilGood (62)
12/04 Sulaiman (71)
Voltage multiplier
basil_brush
Sun Jul 15 2007, 10:00PM Print
basil_brush Registered Member #903 Joined: Sun Jul 15 2007, 09:51PM
Hello. I intend to build a disc based version of a pelletron or van der graaff. In some ways it's a bit like a wimshurst machine. I have drawn a diagram of my proposal and put it here:
http://erik.waterfuel.org/generator.gif
I would much appreciate it if you could take a look at it and tell me if there are any flaws in the design which would reduce its efficiency or stop it from working as intended.
Many thanks,
Erik
Sun Jul 15 2007, 10:04PM
I'm no expert here, but I think the sharp points on the metalic disk sectors would cause corona/leakage.
As drawn, what output voltage do you expect?
looks to me like no more than 6x the +/- inverter?
Myke
Sun Jul 15 2007, 11:48PM
If the voltage were to reach hundres of kilovolts sparks would jump every where or the setup would have to be pretty darn big. You could go with a voltage multiplier if your goal is to make a dielectic break down. I would agree if it were to be over 50KV I would make sure there were no sharp edges as not to make corona which would leak charge and would make the setup less efficient.
Hazmatt_(The Underdog)
Sun Jul 15 2007, 11:59PM
Just so you know, a conventional Wirmshurst machine without the charging supply is capable of producing 100kvdc.
Dr. Drone
Mon Jul 16 2007, 01:00AM
shades
