  • Guests: 52
arnsfelt (46)
jaysun92 (33)
11/30 arnsfelt (46)
11/30 jaysun92 (33)
12/02 Hax (40)
Flyback Driver
Matthew T.
Sat Jun 30 2007, 02:08PM Print
Matthew T. Registered Member #513 Joined: Sat Feb 10 2007, 07:30PM
Hey All,
I have a few questions about a flyback driver that I want to build. I would like to know if I could operate it without the transformer that steps down 220 to 110 V (operate it directly from the 110 V of mains.) Also, Is the isolation transformer that the signal generator is driving the transistor through necessary? (It has a 3 to 2 ratio). If so, could I wind it myself? What kind of core could I use?
More info about this circuit from original location : Link2 (4th page I believe)
Here's the circuit:
1183212128 513 FT0 Image2
Thanks,
Matthew
Sat Jun 30 2007, 03:12PM
Hello,
First, both your drawing and the original drawing are wrong,
the diode across the high voltage supply is the wrong way around
the instant you switch on there will be smoke.
The diode should be reversed - then it will do no harm
it does no good either so just remove that diode.
There is no component to 'catch' any large flyback spikes -
consider a TVS or R-C snubber, or D-C-R snubber.
The transformer's main function is to electrically isolate the signal generator from the live ac mains.
IT is VERY important for safety and should be made with care - your life may depend upon it!
The transformer ratio has nothing to do with the supply voltage
it's ratio is chosen to match signal generator output impedance to transistor input impedance.
Without knowing the generator output impedance the correct Pri-Sec turns ratio cannot be determined.
The circuit diagram that you have there is very poor - too many errors to be a 'reference' design.
Marko
Sat Jun 30 2007, 03:46PM
Hi Matthew
The described circuit will not work the way it's drawn. That diode parallel with filter capacitor creates a direct short over power supply.
I don't think the signal generator will provide closely enough power to properly drive that transistor. You would need to build some kind of base driver, desirably current-proportional drive wich I wouldn't recommend if you are begginer.
Stick to this circuit. Link2
Search the forum and archives, there are tons of information around.. and just ask if you need any additional help. wink
Matthew T.
Sat Jun 30 2007, 05:12PM
Thanks Firkragg,
With the Mazzilli driver, how do I go about putting the primaries in parallel. Is a simple matter of winding the 5 + 5 turns on both cores and connecting the windings to their respective points? I am attempting to put several flyback secondaries in series to obtain a higher voltage. Such technique is described in the old forum :
Also, what is the difference between powering each flyback with an individual driver with the secondaries in series and putting all primaries in parallel and driving with one ZVS driver?
I have tried quite a few things in respect to putting the secondaries of modern split diode flyback in series with little success and need some advice.
thanks,
Matthew
