  • Guests: 19
  • Most ever online: 441
Michael W. (36)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
My first DRSSTC
Bennem
Mon Sept 03 2007, 03:31PM
Are you using Steve Wards circuit?
if so, could you tell us what signals you have on pins of
the 74HC109N flip flop ic?
pin 4 should have a signal from your CT.
pin 1 should have your interrupter signal in.
pin 5 should have your delayed int signal in
and pin 7 is your output signal out to your UCC's
Danielle
Mon Sept 03 2007, 05:25PM
Danielle Registered Member #632 Joined: Mon Apr 09 2007, 01:09AM
ok so on pin 4 with a signal generator I get the correct signal but not with the CT. pin 1 has the inturupter signal, and pin 5 has the delayed. I think the problem is with the CT could it have failed its a purchased one the one used in the EVR mini brute. should I make 2 33 and sires them?
Bennem
Tue Sept 04 2007, 05:33AM
Assuming that your bridge is ok,
the phasing is correct,
and you say that your flip flop circuitry is ok,
before suspecting your CT,
have you got your start up waveforms on the UCC outputs
when your intterrupter is turned on?
failing that, perhaps your CT windings have developed fault?
Mel
Danielle
Wed Sept 19 2007, 02:43AM
ok so im back to debugging and this time I hooked up a speaker to the UCC out the UCC.....22 has nothing coming out of it while the UCC...21 has the interrupter signal.. I think this is the problem, but when I test it to replace the chip with a UCC...21 then I get the signal when I put new 22s in there I don't get any signal, what would cause this 5 fried brand new chips or can I not test the 22s in the same way I tested the 21s? please help I can purchase more if that is the problem or if there is something more fundamental.
Thanks for all the help,
Daniel.
Wed Sept 19 2007, 05:23AM
Stop and think...
The 22s shouldnt be putting out anything unless their input has floated high. The 21s on the other hand are inverting so they will output when enabled and their input is zero.
Danielle
Wed Sept 19 2007, 06:33AM
so then I am back to square 1 as I caint figure out why one IGBT is switching and the other isnt the bridge is fine and everything alse looks good except I dont have a scope for a while to test if the signal is good. is there anything I can do to test what can be causing the problem because I am not getting anything anymore should I test it with a diffrent bridge because Ive swapped out many IGBTs not throwing them away but just trying them.
Thanks,
Daniel.
