  • Guests: 60
Sonic (59)
kamelryttarn (47)
11/30 arnsfelt (46)
11/30 jaysun92 (33)
12/02 Hax (40)
Current in Wooden Telephone Pole Lines?
MikeT1982
Sat Jun 23 2007, 05:47AM Print
MikeT1982 Registered Member #621 Joined: Sun Apr 01 2007, 12:37AM
I have always been curious, out here in the farm area in Pennsylvania, US. we have a coal fired powerplant that supplies the local area. Down my road are the average wooden telephone poles with two un-insulated wires and are probably old as heck, I'm 25 and they were the same when I was born. Back in highschool, a science teacher foudn out for me from his freind who was a lineman that there was about 12kV in these lines. What I never did ask and am wondering now is just how big the short circuit current of one these lines would be? I guess it would have to be decent current to power the homes although there aren't too many....I just wonder if we're talking 10's or 100's or even 1,000's of amps capability..
And then those metal pylons that jump the mountains and are in the 100-200kV range, just how high is their short circuit current?
sparky
Sat Jun 23 2007, 06:20AM
Good question! The large towers are usually rated for 350 kV 650 A .... some lines are 750kV 1000 A running from a power station :)
Sat Jun 23 2007, 08:59AM
The answer depends a lot on where you are. Over here our standard voltages are 11, 33, 132, 275 and 400kV. The wooden poles are only used at 33kV and below.
The load current and fault current depend a lot on where you are in the network. They will both be a lot higher on a street in town than on a farm in the middle of nowhere. The fault current is usually 10 to 20 times what the line carries in normal use.
Either way, for those 12kV overhead lines you are talking load currents in the 10s to 100s of amps, and fault currents in the 100s to 1000s. For the big metal pylons think another factor of 10 up.
