  • Guests: 19
genious 7 (32)
07/13 Friday (55)
07/13 robismor (30)
07/14 EEYORE (42)
SSY Laser
Will1234
Sat Jul 07 2007, 12:50AM
Will1234 Registered Member #846 Joined: Tue Jun 19 2007, 08:04PM
How can I check the continuity of the thin red wire that enters the base of the trigger transformer? Where the lead enters the transformer seems to have a lot of free play in it and not stiff like the rest of the wire i...? Can I apply a small current, 9V, 12v, 24v and see if ANYTHING is registered on the main lead going to the lamp?
Sat Jul 07 2007, 01:32AM
seriously, you need to stop quadruple posting... If you need to have something to add modify the post, or if you want my attention pm/im me.
Your schematics didn't upload, try putting them in a .zip and then uploading them.
Concerning the power supply... When you fullwave rectify a 24vac transformer, you should actually get almost 35v out of it, because the transformer is putting out 24vac 'root mean square', which for a sign wave is 1/rad2 the peak-peak voltage, and when you have little/no load the output 'floats' up a few volts. As to the zener, I do not understand what you did... If you reverse a zener diode it clamps at a much lower voltage, not a higher one (unless you explode it...) In any case, the reason that the supply can charge the cap to a higher voltage than you read when it is freestanding probably has to do with the waveform coming out of the supply, I am guessing that it isn't a pure DC output, but rather short pulses of a high voltage. You meter doesn't accurately measure them, but the cap is still charged by them.
To test the trigger transformer primary, put an ohmeter from the red/brown leads at the bottom, it should read very low (no more than a few ohms). To test the secondary charge up the trigger cap to 200v, and short it across the primary, while the output lead is almost touching one of the primary leads. You should get a small spark (like a piezo igniter)
Will1234
Sat Jul 07 2007, 05:38PM
I attached a zip file with the two source files in it. If I reverse a 200V Zener should it cap the output at the knee voltage (200v) or subtract 200V from the total voltage already on the line? At this point I'm not sure how but if I put 2 160V and 1 200V Zeners backwards the power supply voltage shows up as 735vdc on my dmm with no load other than the dmm. ??
W
]1183829895_846_FT27163_ssy.zip[/file]
EEYORE
Sat Jul 07 2007, 05:53PM
Your really making this more hard than it is...Just scrap the whole idea. Take out the main capacitor(you will also need its inductor so as to not wreck the lamp) and charge it via some sorta power supply. MOT's(on a variac and rectified), and CCFL inverters work great(use a DMM to watch the voltage). Use a piezo grill ignitor to trigger your flashlamp. Bodda bing, bodda boom! Oh yea, and close your eyes when you fire the laser!(Or get proper safety goggles.)
You will later decide you want more power and thus be collecting photoflash caps...
Matt
Sat Jul 07 2007, 06:56PM
The diode connected to pin 2 of the inductor needs to be in parallel with the tube, not in series with it. refer t the 2nd schematic.
The trigger coil is missing a wire, one of the small leads at the bottom needs to go from the contact between the 1m resistor and the trigger cap. (In addition to the lead going to the trigger switch)
I am a little unsure about 'large lead coming out of zener', the zener is a little diode looking thing on the trigger board (somewhat like this )
The circuit only needs 1 single zener diode, across the trigger cap. It should have no effect on the voltage the main cap charges to.
Will1234
Sat Jul 07 2007, 10:27PM
Alright, back to individual components to start over. What I was calling the Zener on the trigger board is the larger aluminum component opposite the coil from the trigger cap. Two leads out of the top and another at its base....
As always again, Thank you all.
Will1234
Sat Jul 07 2007, 10:48PM
I realize this has grown out of control so if you can look at the attached jpg of the trigger cap and clarify it for me I promise to ease back into the shadows and stop being so needy.....
Thanks......
]1183848498_846_FT27163_triggercap.zip[/file]
Sat Jul 07 2007, 11:07PM
The component you speak of is the SCR (q2 in the 2nd schematic), you need the grey/black diode labeled 1n4991
1183849669 56 FT27163 Triggercap
Will1234
Sun Jul 08 2007, 07:02PM
Finally!! I was missing the neg lead to the trig cap.
Sun Jul 08 2007, 08:52PM
so it fires now?
I would do anything I could to find a convex lens with a nice short focal point (<1" preferred, but anything is better than nothing) as the laser is notably more impressive when you focus it down to a nice small spot. If the lens is short enough, and the head in good enough condition, you can actually have enough power density to ionize air, which manifests itself by creating a small plasma ball floating out at the focal point of the laser.
