Light dimmer ignition coil driver, plug polarity?
Dago
Thu Jun 07 2007, 02:32PM
Registered Member #538
I started building a light dimmer + cap + ignition coil driver, I just got all the stuff I needed in front of me and while reading the manual for the dimmer it occurred that does the polarity matter when using a light dimmer on mains driving an ignition coil? In the manual it shows a diagram with the dimmer connected in a certain way (the connectors for the dimmer are labeled with arrows pointing up or down). Can I just put the dimmer + cap + ignition coil in series after my variac or do I have to worry about which way the plug is in the variac/wall?
Tesladownunder
Registered Member #10
Any way is OK. The dimmer is a 2 wire AC device. It would be marginally safer to have the earthed tag of the ignition coil going to the neutral of your mains but no difference to performance.
TDU
sparky
Registered Member #530
I built a 2 double ignition driver for 240V -- 120V each phase into a cap and a dimmer. I got at least 120 kV from the set up!!!
