  • Guests: 30
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
A Question on this NST.
MikeT1982
Sun Jun 03 2007, 07:44AM Print
MikeT1982 Registered Member #621 Joined: Sun Apr 01 2007, 12:37AM
I am curious about this type of NST like this Franceformer in the picture. It only has 1 high voltage bushing and the other little ground seems to go to its case just like a center tap on a regular NST with 2 high voltage bushings...but this one has no center tap. Is the other end of the secondary coil (the one that does not go to the high voltage bushing) actually connected to that little screw AND the case? Seems dangerous in thinking of it! I wonder why these types are made.
1180856659 621 FT0 Pkmpic
Adrian
Sun Jun 03 2007, 10:22AM
Adrian Registered Member #697 Joined: Thu May 10 2007, 12:28PM
I'd say your right. It's apparently grounded as "One End Ground" which doesnt mean much to me. It has no data sheet and there is little other info about it.
Its a Franceformer 3030/4030/5030 PKM-1 if anyone is wondering...
Coronafix
Sun Jun 03 2007, 10:33AM
Wouldn't it just be the same as a MOT?
One end of the secondary is grounded to the core?
MikeT1982
Sun Jun 03 2007, 10:38PM
Yeah that's what I'm guessing, because if the other end of the secondary wasn't connected to anything it couldn't make the 30ma current I'm thinking. The more I think about it, it is really just half of an NST! so its like grabbing the High voltage bushing and centertap of a normal one for power and just cutting the other side off with a hacksaw lol. After posting I kept thinking about it and I'm pretty sure that's what kind of beast this is. (small beast lol).
Billybobjoe
Mon Jun 04 2007, 12:58AM
Billybobjoe Registered Member #396 Joined: Wed Apr 19 2006, 12:55AM
Yes, I'd assume this is just a "half" of a normal NST. I don't see how it would be dangerous (well, any more than a regular NST), as the other end of the secondary is at ground potential. As Goldpshere said it's practically the same thing as a MOT, except higher voltage and lower current. They are most likely made for lower voltage applications for smaller neon tubes, where a midpoint secondary grounded NST wouldn't be necessary.
Bjørn
Mon Jun 04 2007, 01:32AM
Everyone repeat after me:
a stands for are, a unit of area.
A stands for ampere, a unit of current.
Yes it is easy to understand anyway but if we get into the habit of doing it wrong we will soon write things that can be misunderstood. Particularly by people that are still learning.
Bored Chemist
Mon Jun 04 2007, 05:56AM
Look on the bright side Bjorn, he didn't use megamps. Also, if everyone learns the rules (ie that if it's a unit named after a person it gets a capital and if it's a prefix bigger than 1 it gets a capital too) We will miss out on peple bragging about their new 'scopes that are slower than a chart recorder.
BTW, what's 10 to the minus eighteen of an are abreviated as?
Coronafix
Mon Jun 04 2007, 06:23AM
Bored Chemist wrote ...
... if everyone learns the rules (ie that if it's a unit named after a person it gets a capital and if it's a prefix bigger than 1 it gets a capital too)
What about kilo (k)?
Mon Jun 04 2007, 02:32PM
I am guessing that the reason that your NST has only 1 post is either because it was cheaper to design it like that, or because there was a patent/etc dispute between them and someone else. You should be able to wire it in like any normal NST, just use the gnd tap as the other HV out, and don't ground anything in the primary circuit (except for the NST itself).
edit, woops don't let me post from my CCNA class anymore. For us you need a lower case k, kV, kHz, (as opposed to a cisco router which expects a capital K in when referring to such things as clock frequency, or sizes measured in thousands of bytes)
Mon Jun 04 2007, 02:51PM
No, kilo always took a small k. Binary kilo (1024) is big K, or Ki these days.
