  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Signal generator output conversion to 2KV
Dr. Shark
Wed May 23 2007, 07:52PM
Guys, I am sorry I have to break it to you all, but you are horrible gullilbles.
Energyman wrote ...
I am not using much power at all - 2 watts or so.
Your reply falls outside my knowledge base I am afraid. Any idea where I might find the resources for this (plans). I have had a look at the tc4422 and this seems simple enough but I have had no experience using hv mosfets.
This guy is only looking for 2W of power, so I would suggest him to go with a small Krytron tube. I have experience with these as laser Q-Switch drivers, they are good at providing _extremely_ steep risetimes, and will easily source the 2kv/2W = 1mA Energyman requires.
Actually I think I gathered that the "sqare wave" requirement comes from the output pulses of the signal generator and is not a requirement of the load, so a much cheaper tube would also do the job with some distortion on the square wave.
On a more serious note, I suggest you, Energyman to play with some well-understood toys like Tesla Coils and gather the knowlede and equipment you may need for some later experiments with scalar waves. Unless you change your belives on the way.
