  • Guests: 56
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
High Voltage / Carbon Comp Resistors
Wilson
Wed May 02 2007, 02:05PM Print
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
I'll be trying to make a small marx generator in the next few weeks (~10 stages, 30kV, 500pF/stage), probably using these caps. Problem is, I haven't been able to find any suitable resistors frown
I'm reluctant to use film resistors, as the high voltage causes inevitable failure with enough shots, and gradually changes the resistance before that. Been looking for some high voltage resistors, or some carbon composition ones to string together. Anybody have some to spare? Best I've found on ebay are these , but they are a tad expensive, although they should be able to withstand 10kV?
If anyone has some extra caps / resistors, and wouldn't mind shipping to Australia I would love to hear from you smile
Thanks,
Regards,
Wilson
Wed May 02 2007, 08:34PM
Those are very similar to the resistors i use in my 25kV charging voltage marx bank. Only very rarely have they flashed over, and even still they survived fine. Also, the price is rather good considering they are 2W resistors.
Wed May 02 2007, 08:52PM
I have many 2M2 0.5W Metal Film resistors, Type VR37 which is a high-voltage range, 3.5kV peak rated.
For specifications go to Link2 and type VR37 into the search box.
10 in series per 'Resistor' would give 22MOhm 35kV peak rating
I think you'd need 19 sets, for example, 190 pieces total.
I would sell 200 for 10 uk pounds, plus p&p which shouldn't be too much,
if interested I'll get a firm p&p cost (pay me via PayPal)
Look on eBay for similar items, maybe cheaper.
Consider first how to neatly/easily/quickly make sets of 10 resistors.
Maybe single more expensive resistors would be better?
Wilson
Fri May 04 2007, 01:48AM
Sulaiman, I think I will stick to the higher voltage resistors. Don't know whether I have the patience required to make an odd 190 solder joints >_<
I ended up buying 100 of those 2W Allen Bradley resistors from the link above, and 13 40kV caps, which costs quite a bundle XD
Does anyone have any large HV ceramic caps? (In case I decide to scale up the bang energy) The ones on ebay are all around 500pF frown
Thanks,
Regards,
Wilson
