  • Guests: 29
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Can't explain this phenomenon of ohm readings.
r3d
Fri Apr 27 2007, 12:28PM
r3d Registered Member #532 Joined: Sat Feb 17 2007, 05:00PM
Then sorry
Ken M.
Sat Apr 28 2007, 12:34AM
Yeah sorry for incorrect and missleading information....I'm ashamed at my ignorance, especially since I went to college for electronics....
kell
Sat Apr 28 2007, 01:42AM
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
Well, under certain conditions it makes a huge difference how much current passes.
Take one of those positive temperature coefficient heating elements that are made out of some kind of semiconductor, heat to a high temperature; keep the temperature constant and, using test currents ranging from milliamps to several amps, measure the resistance several times. You will find that the resistance is anything but constant; nowhere near it in fact.
I should put "resistance" in quotes because, it doesn't have physical primacy. It's a ratio of voltage and current, which are primary physical quantities. Resistance is a secondary physical phenomenon, an artifact that you can only calculate from those other primary quantities.
But I digress.
Hazmatt_(The Underdog)
Sat Apr 28 2007, 07:06AM
We do have some pretty good information on Transformers here: Link2
Its all 'by the book' from my power class.
