  • Guests: 74
Audio modulated SGTC?
Nyx
Fri Apr 06 2007, 05:29AM Print
Nyx Registered Member #586 Joined: Sat Mar 17 2007, 06:51AM
Is it possible to have a audio modulated SGTC?
ShawnLG
Fri Apr 06 2007, 06:02AM
No.
Nyx
Fri Apr 06 2007, 06:24AM
thanks!
Electroholic
Fri Apr 06 2007, 07:02AM
No?
technically if you have a variable bps, you could get some noise out of it.
Fri Apr 06 2007, 02:07PM
Why not use a triggered spark gap? If it worked "as advertised" it should produce "musical" tones just as a DRSSTC does (though not as cleanly, since DRSSTCs are very well controlled machines). But really, make your spark gap triggerable via ignition coil, and then just modulate the frequency of the drive pulses to the ignition coil. Thats about as close as i think you could come to modulating a SGTC. Will it actually work? That depends on your triggered spark gap and how reliable it is.
Fri Apr 06 2007, 02:39PM
An audio modulated spark gap Tesla coil is fully possible. In fact, Tesla himself patented this concept early in the 20th century (if not earlier)
Fri Apr 06 2007, 04:22PM
All,
Agee with Steve, triggered sparkgap is cool.
Another way would be to use an ultra low inertia rotary. Strong motor so that it can hit that high note fast. and preloaded with a brake so that it could also go deep without undue delay.
I remember someone reporting a gap like this on the Pupman list a couple of years ago.
But hey! Audio modulation is what SSTC`s are all about.
Cheers, Finn Hammer
Coronafix
Fri Feb 15 2008, 04:47AM
I believe another way would be to put a transformer on the ground of the secondary, and magnetiseing it with a dc audio pulse. Thereby in effect, switching the grounding of the secondary on and off.
Do you think it's possible with a Tesla coil, and if so, how many turns on each to achieve the required effect?
GimpyJoe
Fri Feb 15 2008, 05:16AM
Maybe a low voltage (4kv or so) coil could use a simple mechanically triggered gap. A metal ball or acorn nut on an insulating standoff attached to the cone of a speaker would move up and down, closing a small gap. You would still need either a very high charging current or a very small capacitor to achieve any reasonably high frequencies.
Coronafix
Fri Feb 15 2008, 05:28AM
I was thinking a MOSFET driven by the audio signal and saturating the core with a large current to cut off current flow in the ground wire.
