  • Guests: 119
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Warp Light, picture included
CM
Thu Mar 29 2007, 10:36PM Print
CM Banned on April 7, 2007
Registered Member #277 Joined: Fri Mar 03 2006, 10:15AM
Here's a light I made, once upon a time. It's nothing more than some different colored plastic plates I bought at a grocery store, placed holes in the center of, and then stacked on a vertical blacklight. I could vary the power supply causing the blacklight to flicker in a manner that appeared to start at the bottom and ripple up to the top, then repeat, either fast or slow repetition. It made the plates light up in sequence from the bottom, up... kinda reminded me of the 'movement' of the warp engine light from the original Star-Trek, thus the name WARP Light. shades CM
1175207934 277 FT22694 Warplight1reduced
[Edit: Fixed double post]
ragnar
Fri Mar 30 2007, 04:24AM
Aw, cute, CM.
Have you seen Mike (as in Mikeselectricstuff) musical tuned discharge pipes? Your contraption reminded me of it for some reason :P
Myke
Fri Mar 30 2007, 04:43AM
that looks cool cause it looks almost fake but real at the same time. wink
CM
Fri Mar 30 2007, 02:51PM
BlackPlasma:
No I've not seen Mikes... is there a link? or in the archives where I can see it? CM
Dr. Shark
Sun Apr 01 2007, 09:00AM
Mikes Spark-o-phone is on his homepage here Link2
Maybe you could couple your device to a HV contraption of some sort, too?
Zum Beispiel
Sun Apr 01 2007, 06:40PM
That's pretty cool. Neat!
CM
Sun Apr 01 2007, 09:12PM
Joe:
Thanks.... that spark-o-phone is pretty cool. I like. CM
Ken M.
Sun Apr 01 2007, 10:34PM
Hrmm, I keep looking at it, and the more I do the more I think about making 1 using HV power source maybe like an out of tune SSTC, and have a backing to hit to protect and hide the HV source. Then either wall mount it or be crazy and ceiling mount it! shades Looks cool though! wink
kalenedrael
Tue Apr 03 2007, 02:21AM
kalenedrael Registered Member #5 Joined: Thu Feb 02 2006, 04:18AM
That is pretty neat. It seems like an excellent novelty room decoration. How bright is it?
Ken M.
Tue Apr 03 2007, 02:29AM
By the looks of it i'd say no more then the amount of light put out by a 15w light bulb.
