  • Guests: 63
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
nst voltage doubler
jameselectric
Mon Mar 05 2007, 11:12PM Print
jameselectric Registered Member #535 Joined: Sun Feb 18 2007, 06:03AM
just wondering if this is possible like with a mot and the diodes and whatnot?
Mon Mar 05 2007, 11:17PM
Sure is possible.
You want to run a TC off of it? Keep in mind that working with HVDC supplies like this require some other components to make them work with TCs. You will need some sort of choke (inductor) between the HVDC and the TC circuit, otherwise when the spark gap fires it will discharge your voltage doubler capacitors. The inductor "isolates" the 2 circuits to some degree, keeping this from happening. The inductor is very large value, probably the reason many people DONT run DC supplied tesla coils.
Matt Edwards
Mon Jul 25 2011, 09:34PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
What ever happened with this? were you able to successfully create a working circuit?
Tetris
Mon Jul 25 2011, 11:40PM
My NST isn't powerful enough for my coil. If there is a doubler for it, (SGTC failcoil) I need it, as my SGTC is more of an air cored NON-RESONANT transformer XD
Tue Jul 26 2011, 07:07AM
jameselectric wrote ...
Yes, of course it is possible. The reason that it is rarely done is because of the considerable cost and physical size of the capacitors needed in 50/60 Hz voltage multipliers.
It can still be viable if only a few mA or less are required - but not a lot of use to Tesla folk.
Sat Aug 13 2011, 09:08PM
Where does the MOT come in exactly?
There is no point in using a voltage multiplier with an NST for a Tesla coil. More voltage means you would need a bigger spark gap, which i think would be less efficient. It would dissipate more heat i would think.
With a voltage multiplier for a Tesla coil power supply, you would have to use a high voltage choke, which would have to be very very high voltage, especially due to the high voltage from an NST with a doubler. The choke would have to be rated for around 2 times the voltage of the supply, and then with higher voltage you would need more inductance. That would be insanely expensive. If you where doubling a 12kv NST, the choke would have to be something like 40kv and probably 20-40H, which i don't know if they even make those. Winding one would suck.
Dr. ISOTOP
Sun Aug 14 2011, 06:15AM
Arcstarter wrote ...
It matters for a MOT, where the stock voltage is too low to trigger a spark gap reliably.
Adam Munich
Mon Aug 15 2011, 08:12PM
HighVoltageChick wrote ...
Make it resonant and you'll find that an NST can make a rather impressive coil.
