  • Guests: 66
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Teaser/preliminary pic for upcoming project...
ConKbot of Doom
Sat Feb 17 2007, 08:20AM Print
Nothing too fancy but it will let me put together a few different areas into one project using a PIC.
In the attached picture,
From the top,
PIC 16F877A, one I had laying around, may or may not be used, might pick another uC.
Underneath that, (in the IC tube of 20 SOIC-8 chips)
Fairchild FAN7382M
Down and to the right of that, a nice pile of RGB LEDs
The single DIP16 chip next to those, is a MAX232 (or another variety of the same family)
Below that is 5 TLC5940 chips.
To the left of those is a BQ4285 kind of dated but it'll do what I need.
To the left of that is 8 mosfets, n-channel, 60v, enough amperage, nothing special here...
Above that is the stepper motor.
Anyone else like what they see? Any guesses, no cheating if you browse bit-tech too tongue
1171700357 509 FT0 Dsc05876
Dago
Sun Feb 18 2007, 08:36PM
Sounds like a computer controlled RGB led matrix I suppose :P
AndrewM
Mon Feb 19 2007, 12:04AM
Obviously a helicopter.
Sam
Mon Feb 19 2007, 12:19AM
Sam Registered Member #227 Joined: Mon Feb 20 2006, 10:47PM
no way, Its a nuclear fusion reactor controller...
Is that legal where You are?
ShawnLG
Mon Feb 19 2007, 04:33AM
Its a PIC controlled SSTC with multy color LED for 7331ness. I guss he will use the magnet wire inside the stepper moter for the secondary.
Electroholic
Mon Feb 19 2007, 05:28AM
its a RBG POV display
Mon Feb 19 2007, 06:28AM
Is the stepper bipolar or unipolar? Thats very important.
Mon Feb 19 2007, 10:50AM
Is it a propeller clock with full colour display? smile
ConKbot of Doom
Thu Feb 22 2007, 11:40AM
ShawnLG wrote ...
Tesla coils go in the tesla coil subforum tongue
Steve Ward wrote ...
That particular motor is bipolar, but I believe 6 or 8 wires actually do come out of the casing, with only 4 hooked to the connector. I may end up using another one.
Steve Cønner wrote ...
Thats what I certainly hope it will be, certain things may have to change, like a different stepper motor, the one pictured is 400 steps/rev. I have some 48 steps/rev motors I got in the mail.
Considering the amount of data needed for 16 bit color, if I want to do full graphics (I.E. be able to load a bitmap onto it to display, not just multi color text) I'm going to need some RAM too, ~300 bytes on a PIC wont do for a 16x200 16bit color image
One question though, someone on another forum suggested that speed would be an issue with the stepper motor, saying the most he could get out of a stepper motor he was playing with was ~120RPM, overdriving it with 15v instead of 5v and it was a 9 degree/step motor, I find a maximum pulse rate of 80 pulses/sec to be quite low, especially reading other web sites, Ive seen numbers in the 400's up to 1500 pulses/second if not more, and motor drivers that can handle 25000 pulses/second.
I know it all depends on the motor inductance and load, but what sort of pulse rates would be a more real-world estimate?. 960 steps/second with a 7.5deg/step motor would give me 20 FPS which should be sufficiently smooth, 480 steps/sec would be 10 FPS which would be about the lowest I would want to go. If I cant get that, I'll just use a DC motor with a reduction, and a photo-transistor/IR LED to index the arm, and a PID loop on the controller for the motor to maintain a constant speed.
Its gonna take a while to build between limited time, to work on it, and not having any real experiece in any of these areas, but I think I'll be stubborn and actually get this done.
Thu Feb 22 2007, 12:21PM
I think the noise of a stepper motor running at 960pps will drive you crazy in about a half hour. Wheeeeeezzzzzzzzz.... Probably best to use a DC motor with an optical or magnetic index pulse thingie, it will be much quieter.
