  • Guests: 39
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Ambient Energy LED lighting contest!
Wed Feb 14 2007, 08:19PM
On the otherhand, I managed to light the LED again. Below is a 6" diameter coilform in my hand near my monitor.
1171423248 286 FT20570 Magavor Led
That's cool.. Can you clarify a bit more how you did that?
To contribute to thread somewhat..
I built a small blocking-oscillator LED driver, wich uses a germanium tansistor and was able to start from just 150 milivolts input.
I left some soaked paper to cool outside, and after I put it under one side of peltier it produced up to about 200 milivolts, enough to nicely light the led.
Then I tried heating it just with my hand, and it gave 160mV, barely enough but LED did lit. I guess my body heat is also considered 'waste' energy here.
Maybe If I covered myself in a suit of peltiers and stayed in cold enviroment, I could produce few watts and power a pocket PC or charge a cell phone.. tongue
1171484367 89 FT20570 Peltier 3
1171484367 89 FT20570 Peltier 6
Some cheap calculator cell thrills. Next sunny day I'l try torching the peltier with that mirror and see how much power can I get...
Steve?
1171484367 89 FT20570 P1010092
Finally, a use for those things! Not surprisingly, I still have a whole bag of them. I just connected one up to a red LED and tapped the can with a spanner. It caused a very feint flicker of the LED. All I need to do is find a way to mount them all on a solid surface such as a block of steel, in a way whereby they will all be in phase when tapped, then I can parallel them and fullwave rectify the output with some ultrafast diodes. I suppose I could then go ahead and stick the whole array onto the washing machine or something.
Bag of these is pretty nice.. although I see a problem with paralelling/seriesing because you need to have them all in phase for that, but if they are mounted firmly they may just work.
Piezo's also act pyroelectrically, and you can turn them into heat engines by cooling and heating them rapidly. Not great efficiency, but I managed to blink a LED from a single piezo speaker that way.
J. Aaron Holmes
Wed Feb 14 2007, 09:37PM
Firkragg wrote ...
...this is starting to sound a bit like some Frank Herbert novel. I suppose you could also build some sort of minature wind farm into something that fits over your mouth, then charge your cell phone whilst sounding like Darth Vader.
Regards,
Aaron, N7OE
Wed Feb 14 2007, 09:59PM
You beat me to it.. I'm not sure if it could be that powerful without seriously impeding breathing, but may work for a LED...
There are fortunately better ways to extract human power than peltier plate mail or mouth-wind turbine ill
ShawnLG
Thu Feb 15 2007, 04:42AM
"There are fortunately better ways to extract human power than peltier plate mail or mouth-wind turbine"
This would easly light an LED.
Update:
"That's cool.. Can you clarify a bit more how you did that?"
The monitor's deflection coils leak a lot of magnetic flux. So my coil suck up some of the stay flux.
The Piezo powered LED works with regular piezo speakers also.
1171515870 286 FT1630 Piezo Led
I blew air across the opening causing the cavity to resonate it and it generated enoff volts for the LED. Tapping it also works. I could pin a bunch of these piezo powered LEDs on me and go a night club and have the music power the LEDs. cheesey
J. Aaron Holmes
Thu Feb 15 2007, 04:33PM
ShawnLG wrote ...
That's a pretty cool idea, actually. It makes me wonder: Similar to the thing about living near 440kV power lines, what if people living in cities or near major highways could use this technique to farm the white noise generated by all the traffic? Have a bunch of satellite dish-sized parabolic microphones aimed down at the street from your highrise apartment smile
Regards,
Aaron, N7OE
Coyote Wilde
Fri Feb 16 2007, 06:56AM
Coyote Wilde Registered Member #175 Joined: Tue Feb 14 2006, 09:32PM
Americanium betabattery?
... something tells me men in black suits wouldn't like it if I tried to gather enough smoke detectors for that. angry
Of course, if I had the Am-241, I'd probably put it in aqueous solution with some phosphor and get the light directly, but the betabattery has geek-points appeal. Anyone with hot rocks want to see if they can make a big enough pile of 'em? :P
The piezo idea would be even better for anyone living near train tracks... get a big freight train going, and you can feel though your boots how much power is there--literally, the ground shakes. Actually, there's probably enough power in that to run the warning lights at crossings.
Didn't someone have a plan once of putting peizos in bridges and such?
Hey, how about I open a gym? Plenty of free power there. And it's not slaver labour... they're paying ME to get in. cheesey
Fri Feb 16 2007, 10:33PM
Single piezo also worked for me, but only by tapping it; it didn't care about any sound around. Maybe it would if I attached some bigger external membrane or mass to it.
It's hard enough to get significant amount of visible light from exempt amount of americium, yet alone something that would produce electricity via thermocouples or photovoltaics.
Beta batteries, obivously, work on beta radiation, and tritium is commonly used.
They are something like wierd diodes encapsuled with tritium wich produce voltage by bombardment of PN junction with beta radiation. Not something to be built in a hobby shop. Link2
Self Defenestrate
Sat Feb 17 2007, 01:08AM
Coyote Wilde wrote ...
I had that idea a while ago too. It was followed by the idea of strapping magnets to deer and having them run through coils for food to generate current, but i fear PETA would come after me. My contribution to this contest isn't great, but i did manage to light an led with a roll of scotch tape, grounded one leg and held the other leg near the roll of tape as it was dispensed and the led lit rather dimly from the static created, but it was a quicky idea with parts i had on my desk. It wasn't free however, it cost something along the lines a buck or two, and some hair off my arm from removing the tape.
Bjørn
Sat Feb 17 2007, 03:06AM
I have managed to get detectable light (under perfect conditions) and a detectable current by collecting ions from the air around it. So far I have not been close to light a LED.
Avalanche
Sat Feb 17 2007, 06:06PM
This thread got me looking into peltiers a bit more, and I noticed you can pick up fairly cheap peltier coolers like this off eBay. That one is rated 34 watts input, I wonder how well they would perform in reverse as generators? Waste heat is easy for me to get hold of, because I use a hurricane lamp quite regularly. One of those installed in the top of the hurricane lamp might not only light an LED, but I'd actually have a use for it (charging my phone and batteries) whilst camping. I wonder how many watts I could draw? The only problem I'd have to overcome would be overheating the module, but that shouldn't be too difficult to get around.
