  • Guests: 45
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Ambient Energy LED lighting contest!
CM
Mon Feb 12 2007, 07:02PM
CM Banned on April 7, 2007
Registered Member #277 Joined: Fri Mar 03 2006, 10:15AM
Stop4stuff:
Very cool device you made, I watched the video. It's creative thinking like yours that is to be admired. If you come up with other neat power device, please let us know. CM
ShawnLG
Mon Feb 12 2007, 10:00PM
Some may remember this "free" energy experiment. So I built it again for the 3rd time.
Money invested:
CM: $100,000
ShawnLG: $0
Time invested:
CM: Years
ShawnLG: 5 min
15 feet of wire was used as an antenna and the grown connected to a grounded object.
1171317652 286 FT20570 Free Power
Mon Feb 12 2007, 10:25PM
Nice.
What kind of ground are you using?
One time I connected a pretty log antenna to a blue led, grounded to mains ground, and was pretty suprised to see it lit without any resonant circuits.
After some fiddling I figured out that various rf hash and harmonics induced in ground wire by warious appliences powers the led, and antenan just capacitively coupled other end to ''real'' ground. It worked much netter when I connected it to grounded rod.
ShawnLG
Tue Feb 13 2007, 12:35AM
"What kind of ground are you using?" The house's heater, which I know is earth grounded.
ragnar
Tue Feb 13 2007, 01:17AM
I have a large metal sheet on my desk for solder-splash protection. If I wave my one arm in the air, I can light a low-voltage (red/yellow) high-brightness LEDs by touching them to the sheet. ^_^
I guess the fields from the nearby three-phase lines help.
Tue Feb 13 2007, 10:43AM
BlackPlasma, omgpix plz! If you can show it working, you get points for simplicity wink
Tue Feb 13 2007, 01:29PM
Guessing blackplasma's metal plate is grounded, it's obivous that he can light a led that way.
As I already mentioned, most house grounds often float with few volts of HF noise wich is usually enough to barely light a led just by capacitively coupling another leg to ''real'' ground,
by holding it by hand, connecting to a large metal objects, real earthed wire (works best) etc.
This may also have influenced shawnLG's setup (heater ground?) although I'm not sure.
Just need to recharge my camera and I'l post a pic of that 'phenomenon'. smile
CM
Tue Feb 13 2007, 01:51PM
Shawn:
Looks like you replicated a simpified tuned version of the Tate Ambient module U.S. patent 4,628,299 Link2
If so, it's not "free" environmental energy, it's running off of manmade RF or AC signals. Steve's challenge clearly says "FREE" in the title. Btw, R&D costs can be $0 when you take them from someone else, if so, you should have the decency to give Joe Tate some credit for 'your' submission. mistrust CM
Dr. Shark
Tue Feb 13 2007, 03:00PM
Sorry CM, steve specified that
Steve Cønner wrote ...
... By that I mean renewable energy, or energy that would otherwise have gone to waste such as ambient RF or EMI from your electronic toys.
but you are right, most of the ideas here would not work in a remote area of the planet with no electricity around to suck power from.
Also there is the small matter that a fairly dark-adapted eye can probably see an LED glowing at 1µW or so. It would be more challenging to generate a more significant amount of power, e.g. 1W for free, as this could be used to power an iPod or mobile phone.
Tue Feb 13 2007, 03:24PM
Hi again, Steve and folks.
I can generally just connect a LED to my mains ground, and it will be lit pretty well if I hold her in my hand.
It also works if I connecto another end to anything with significant (few pf) capacitance to ground, like alu box on pic. It worked with a TC toroid, few meters of wire unwrapped around my room, and etc.
Interestingly, nothing worked better than my body, even a large metal barrel I happened to have around.. LED is still brightest when I hold her by hand.
This may explain some of 'mysterious' free energies appearing between various ungrounded objects and mains ground. Mains ground noise actually _is_ what provides power to LED.
I don't think it's some kind of renewable energy source but rather 'waste' power wich steve also allowed.
It costs nothing, but power generated isn't of much use.
At this time, here is apocalyptically cloudy, so no solar cells neutral But we have pretty much enough wind...
1171380238 89 FT20570 P1010089
1171380238 89 FT20570 P1010090
