  • Guests: 42
Hanzie (31)
badger (52)
h3X (40)
01/12 RoV IW3IPD (63)
Transformer thingie.
Wendell
Wed Feb 22 2006, 01:26PM Print
Wendell Registered Member #73 Joined: Thu Feb 09 2006, 09:08AM
I found some interesting coil assemblies at work recently. They are left over parts from a watt-hour meter manufacturing process that we no longer operate. (Photos provided)
I connected the dual winding thingie to my 3055 driver in place of the flyback and it oscillated verry nicely near 60 hz. The laminations got tosty warm after about 10 min. (eddy current) Did manage to scope the base and observed a nice clean pulse near 35v pp. When a screw driver is placed in the gap the pulse rate goes down slightly. Supply is 12vdc current unknown.
Will connect an ignition coil in series with the main winding when I can find a good one. Lots of unanswered questions but will be fun learning.
Thanks
Wendell
1140614791 73 FT0 Xfmr
1140614791 73 FT0 Coil
Omicron
Sun Mar 26 2006, 03:19AM
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
Its not a transformer, it looks like a moter of sorts.
