  • Guests: 57
01/13 si2030 (62)
Electrical fires
Sat Dec 23 2006, 08:36PM Print
http://www.youtube.com/watch?v=2tCuzys-1P8
http://www.youtube.com/watch?v=-iClXrd50Z8&NR
0_o
Alex
Sat Dec 23 2006, 09:20PM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
Impressive.
There are a few good electrical fire videos floating around, maybe someone will link them.
Marko
Sat Dec 23 2006, 10:08PM
Steve's second video is here Link2 along with some famous flashovers and explosions.
Some other I came across over time:
Link2 - stuck crane
Famous exploding guy:
I also ran into these. Not much of quality, though...
Link2 - why did it flash violently...?
Sat Dec 23 2006, 11:10PM
The tree one flashed really bright because there was one long conected flame. In the first part of the video the flames were seperated a bit and flickered in the middle. When the flame made one uninterupted path from wire to wire it turned into a power arc. I have messed around with my MOTs and candles/wood and have seen similar things occur (just not as big).
The crane reminded me of a sheet i was handed at work, It detailed electical accidents on construction sites. The most common thing mentioned was dumptruck drivers. When the buckets hit power lines the drivers first reaction is to jump out of the truck. Of cource when his feet hit the ground and his hand(s) are on the door he becomes the shortest path to ground.
Alex
Sat Dec 23 2006, 11:55PM
Link2 Here's one of the ones I was thinking of. If I recall correctly, that's a half million volt line. They're supposed to switch them when the power is off, but obviously that didn't happen. In the original you can hear people cheering when the arcing stops.
[edit] And here's the other one. Link2
ShawnLG
Sun Dec 24 2006, 01:00AM
Cool, a jacobs ladder!
Sun Dec 24 2006, 01:15AM
^I've never seen them do that before.
/afk new project
ShawnLG
Sun Dec 24 2006, 03:18AM
Arcing
Burning Focus
Burning Focus 2
Burning Focus 3
Crain hits powerline
The utility company installed these wires too close
Wire down
Undergrownd electrical fire
Another jacobs ladder effect
bear climbs utility pole
Transformer fire
What happend here?
Transformer burnout
More transformers burning out
Another explosion
Korea loses power
transformer fire
arcing
Sun Dec 24 2006, 04:02AM
"The utility company installed these wires too close"
I would say wind or a car hitting a pole caused that
"What happend here?"
Cop car touched the downed line and the line touched a sewer grate or other large gounded object. When ever I am working at a site where the service is being switched no on is alowed to watch the hydro workers as they do it. That way if it screws up we don't all go blind.
Avalanche
Sun Dec 24 2006, 01:06PM
Awesome vids tongue
We used to have regular powercuts here, several a year, caused by an exploding cable under the road..! I don't know what caused it, but it apparently would just keep going in different places. Seemed unusual for a cable that is buried, eventually they just replaced the whole lot. The last major powercut was caused by a pole pig fire in a nearby field, I missed all of it.
When there are major supply problems, they sometimes install a huge (container sized) diesel generator hooked right up to the lines, and whole nearby area goes off-grid!
