  • Guests: 51
Laser module...
Avalanche
Wed Nov 29 2006, 11:33AM Print
... or death ray more like?
I'm surprised this is allowed on eBay, it could do some serious damage in the wrong hands!
amazed
Marko
Wed Nov 29 2006, 12:43PM
$100 is practically gratis if that thing works at all...
The diode is mounted in a NICE heat sink assembly with a collimator / focusing lens. When focused to a point it is easily capable of cutting through many materials. This diode is capable of up to MULTIPLE WATTS of 800-810nm IR and has a built in thermal sensor. NOTE: PIN OUT/ SAFETY DATA for the diode will be supplied.
Author doesn't provide much tech specs with it, though.
Chris Russell
Wed Nov 29 2006, 03:01PM
Chris Russell ... not Russel!
Wow. Just wow. Someone here ought to buy that, rig up a modulation scheme, and try to make some contacts via moonbounce.
Wed Nov 29 2006, 04:48PM
I am not sure about the UK ebay, but in the US there has been a HUGE influx of high power lasers. Eveything from 50w fiber coupled monsters to my 20w unmounted bars.
2 months ago when I started watching the market a diode like that would go for ~$500. Now I doubt it would break $200, probably closer to $100. I saw a few 20w fiber coupled modules go for $120. suprised
Just be warned, that module isn't anywhere close to being cumlinated, the beam coming out is total crap for anything other then pumping a Nd:YAG rod or as a laser welder. It is nearly impossible to get a decent beam strait out of the laser, really you need to build a Nd:YAG laser pumped by a laser like that if you want a 'real' laser with a round beam that has a few mR of divergence.
If anyone is interisted I has ~25 20w and ~20 50w unmounted (but I am working on changing that, just need time) 808nm bars. Just sold a 20w for $70 on the US ebay.
