  • Guests: 48
Next topic »
Full wave rectification of microwave oven transformer
Afrodita
Wed Apr 02 2025, 10:48AM Print
Afrodita Registered Member #4092 Joined: Mon Sept 12 2011, 06:59AM
Hi All,
I have been building Tesla Coils for many years. I have typically used NSTs and PDTs as the power supply. Recently I built a dual MOT power supply, which worked well, however, I want to change that to a dc supply. My question is can I full wave rectify a single MOT transformer for powering a small classic spark gap Tesla Coil.
There is a simple circuit on the internet, but it is only half wave rectified, which I think is wasteful.
RoV IW3IPD
Wed Apr 30 2025, 04:38PM
RoV IW3IPD Registered Member #64746 Joined: Sat Sept 08 2018, 09:22PM
It depends on how your MOT is built, because you need a good electrical isolation on BOTH HV terminals to full wave rectify. Normally one terminal (beginning of winding) is grounded and may even not be accessible. The normal configuration is as a voltage doubler, and in that case both half sinusoids are used.
Thu May 01 2025, 06:40AM
For a given power level,
a static spark gap TC operates better with higher voltages rather than higher currents,
so I think that your best bet is a voltage doubler,
or even a multi-stage voltage multiplier.
