  • Guests: 67
Disambiguation of PIC16f877As general purpose registers
The Zander
Wed Nov 22 2006, 10:11PM Print
The Zander Registered Member #295 Joined: Tue Mar 07 2006, 06:59PM
I've run into some problems whilst building an ASCII -> 7X16 segment display converter (i feed it a serial stream of 7 X 8-bit ascii values, it displays them using 7, 16 segment LED displays). i won't go over the program because its a little long (400lines) to post. but i think one of my problems my lie in the addresses i have assigned as variables. looking @ the 16F877A datasheet (page 19) it looks like everything from 20h - 7Fh in bank0 is available for me to use for whatever i want. is this assumption correct? the reason i ask is that i have seen several PIC tutorial quote general purpose register ranges smaller than the indicated region on the datasheet (these tutorials were for various PIC models).
Thanx
-TheZander
Wolfram
Wed Nov 22 2006, 10:22PM
You mean bank 0? If you mean bank 0, that's right, the 96 bytes from 20h to 7Fh are free to use for anything
The Zander
Wed Nov 22 2006, 10:45PM
yes, i meant bank0 (previous posted edited)
thank you
Thu Nov 23 2006, 12:29PM
I believe the top few addresses (70 to 7f IIRC) are mirrored in all memory banks.
