  • Guests: 30
  • Most ever online: 441
TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
Didgital volt meters going bonkers wile coil is running ...
Vigh holtage
Fri Dec 29 2017, 11:52PM Print
Vigh holtage Registered Member #61739 Joined: Wed Aug 23 2017, 04:43PM
Okay I got two new didgital meters installed in my isolation variac one meter monitors the power coming in from the breaker and it is placed before a noise filter in the circuit, that one is fine , however I have a voltmeter on the output terminals after the isolation Transformer and this volt meter Goes Bananas once I put more than 40 volts into my coil
Is this back EMF coming through the line going across the terminals and being picked up by the meter ? or is this just RF interference and electromagnetic waves in the atmosphere itself causing the meter to freak out on me
Would adding a ferrite toroid to the voltmeter pickup wires stop the interference or is this just a proximity thing ? me being too close to the coil with the variac
The variac unit was only 10 to 15 feet away from the Coil producing 2 foot arcs.
profdc9
Sat Dec 30 2017, 12:36AM
profdc9 Registered Member #58522 Joined: Tue Mar 15 2016, 08:33PM
A ferrite toroid could work. You could also try using a 0.01 uF across the power and sense terminals as well if the signal is slow.
Dan
Sat Dec 30 2017, 10:21AM
How about an analog voltmeter?
L300
