  • Guests: 42
Website Image question - Transparent Images
Tue Nov 14 2006, 12:57PM Print
Just curious to find out what you expert web designers out there use for images that support transparency (alpha channel) when creating websites.
PNG32 seems like it will do the job, although i'm not sure if its good practice to use this format yet since not all browsers support this.
What are your thoughts ? ? ?
Tue Nov 14 2006, 01:20PM
I tend to use .png just because it looks an awful lot better than a .gif typically does. Even though older flavors of IE dont support it properly, the image is still visible. It just looks funky.
I'm not sure about Opera and some of the smaller browsers, but IE7 and Firefox both handle them just fine, and it seems like support for it wll only continue to grow, so it seems reasonable to use .png and maybe have a little blurb on the main page that suggests IE7 or firefox.
Dave
Tue Nov 14 2006, 01:44PM
Cool, thanks. I'll give it a shot!
Bjørn
Tue Nov 14 2006, 07:01PM
.PNG supports both Alpha and Index transparency. IE6 only supports Index transparency. I have not looked at the specifications but if you can make a .PNG file with both then the file will work optimally on IE6 and better browsers.
Index transparency selects one colour to make transparent just like .GIF does it.
Alex
Tue Nov 14 2006, 08:22PM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
That pretty much sums it up, but I figured I'd throw in an example of an application involving alpha transparencies. The author talks a bit about browser compatibility and workarounds; you might find it useful.
ragnar
Tue Nov 14 2006, 09:16PM
I've used a technique similar to the PNGhack a couple of years ago when IE5 and IE5.5 were still popular.
For compatible browsers like Firefox, the PNG is displayed as normal as you'd expect. For browsers like IE5.5 and IE6, it uses the alphaImageLoader() behaviour to get it to display properly, and for IE5 it would substitute a .GIF (with indexed transparency) instead.
The PNGhack although not perfect, is pretty straightforward for you to implement with a minimum of fuss.
Avalanche
Tue Nov 14 2006, 09:30PM
Another technique I used to use to obtain similar results to the above was to create a 4x4 gif image with 2 transparent pixels, set it as the background image of a cell, repeating on the x and y axis.
I used this on the menu bar on this site. I thought it was pretty neat, and it's guaranteed compatible with old browsers.
Electroholic
Tue Nov 14 2006, 11:52PM
That is a neat trick!
