  • Guests: 104
Kolas (18)
Dillon4DynamicHarmonics (41)
12/25 Kolas (18)
12/26 buxtronix (50)
SATA comunnication MASER/SLAVE crosover chip
Linas
Fri Oct 14 2016, 09:40AM Print
Hi,
For a project i use SATA cables to communicate between two fpga's at 200Mbps
Only problem is we need to change device from master to slave and that should be achieved with some kind solid state device.
So in short, i need ; analog switch that can handle at least 500MHZ and Rds should be in a range of few ohms.
Any idea what could i use ?
Hydron
Fri Oct 14 2016, 01:06PM
Hydron Registered Member #30656 Joined: Tue Jul 30 2013, 02:40AM
should be lots of analogue switches designed specifically for SATA, also a lot for other high speed PC interfaces such as PCIe, USB3 etc. Assuming that the signalling you're using is in the same voltage range should be easy!
Carbon_Rod
Fri Oct 14 2016, 01:49PM
You could look at the DS125BR820 with the LVDS i/o...
A word of caution about using multiple FPGAs, as the way most clock multipliers work will often require a special sync'ing signal loop through both chips. Note that a PLL clock multiplier still only really guarantees sync at the base clock input Hz, and the actual transitions per second is not always linearly distributed even if they share the same clock source input. Thus, there are several constraints this will introduce to your design, and essentially will make coordination very difficult to mix chip models that significantly differ or don't support the sync'd clock loop.
Also, multi-master LVDS prefers matched impedance lines, and may require your design correct for the cable characteristics.
You may find a larger FPGA will be the easier solution.
wink
DerAlbi
Fri Oct 14 2016, 10:54PM
There are USB2 Switches... these should by definition work up to 480MHz, so it would be a perfect fit.
Linas
Sun Oct 16 2016, 07:44AM
DerAlbi wrote ...
yes, it looks like this is best option, because USB is single line duplex connection.
Link2 Like this one, just need two of this, for Rx, and TX channel
Linas
Tue Oct 25 2016, 07:43PM
yes, with USB switch and even very bad layout, our communications is happily running at 200Mbps based on pulse width modulation, happy days :)
