  • Guests: 66
David (39)
12/23 David (39)
12/25 Kolas (18)
Where to get a PRECISION 1m rule
Wed Oct 05 2016, 09:54AM Print
My plans for a primary reference mercury manometer & barometer are progressing,
I now need a ruler/measure that I can be sure is accurate to 0.1mm in 760mm ....
markings/precision of 1mm or 0.5mm sufficient.
Looking at eBay I could not find a ruler with the guaranteed accuracy required,
any ideas ?
Carbon_Rod
Wed Oct 05 2016, 11:08AM
Starrett Vernier 72" Callipers
model 123Z-72
About $2k used...
A local Machinist could also cut a steel reference for you.
Wed Oct 05 2016, 11:55AM
Carbon_Rod wrote ...
model 123Z-72
About $2k used...
anything about 100x cheaper ?
I only need measurement precision (scale markings) of 0.5 or 1mm
but I want that precision to be accurate to 0.1mm ... if possible on a budget :)
Wed Oct 05 2016, 12:44PM
Looking forward to seeing pictures of your project.
If it's for measuring ambient air pressure, then the marked scale doesn't need to be 760 mm long. You could use a short metal ruler permanently fixed to a long bar, with one mark at the far end. You would need to get it calibrated once.
A 760 mm stainless steel bar elongates 0.1 mm for every 8 °C. Maybe you can choose a bar material that will compensate for the thermal expansion (density change) of the mercury column. smile
Who knows the tempco of common digital readouts on milling machines?
Rich
Wed Oct 05 2016, 01:12PM
I want absolute pressure measurement over -1 atm to +1 atm using mercury in a U-tube as an absolute reference
as a barometer I will use my vacuum pump for zero pressure reference (<0.01 mm Hg abs.)
(with compensation for scale length and mercury density vs. temperature, standard corrections)
based on a discussion elsewhere, I just measured my 1m steel ruler (KDS Japan) using a cheap Chinese digital caliper,
I set the calipers to 100.00mm and within the limits of my eyesight, the ruler and calipers agree !! :)
good enough for now ... one day I may come across something better
thanks for the thoughts
Wed Oct 05 2016, 01:19PM
Oh, and don't forget to look up your local gravity. The same pressure that supports 760 mm Hg at latitude 45° will support 762 mm at the equator and 758 mm at the poles. Smaller variations come from local earth composition, elevation, and the tide.
I learned that the torr is defined as 1/760 of 101.325 kPa. Once upon a time, did the exercise of backing out "standard" gravity to see if the standard torr matches the literature density of Hg at 0 °C or 20 °C.
Wed Oct 05 2016, 01:42PM
yes, I forgot to mention gravity (but did not actually forget it) ... thanks.
initially I will use lattitude, longtitude and altitude to estimate g
(9.8126 is my current estimate)
I may re-distill the mercury, and measure its density, just to be confident
I bought it via eBay as 'double distilled', but who knows?)
To measure g I may make something like a 'seconds pendulum' Link2
now that I know that my ruler and calipers seem accurate enough (not sure if my metalworking is up to it though )
actually more difficult to achieve effective pendulum length than constructing a barometer :)
Hazmatt_(The Underdog)
Thu Oct 06 2016, 01:13AM
You only need about 25 cm, or 1 foot, because you're really measuring down from the sealed end of the manometer.
Thu Oct 06 2016, 02:06AM
my manometer/barometer is of the U-tube type
this is to cancel meniscus depression errors
and provide an absolute measurement ... no callibration required.
So I need to measure from one meniscus to the other.
I could measure from the zero line (same pressure each side) to either meniscus then double that
but as a barometer it would need to be 'zeroed' before each measurement ... inconvenient,
plus the zero changes with temperature (glass and mercury thermal expansion)
Single tube barometers (e.g. Fortin type) need to be calibrated against a calibrated barometer.
