  • Guests: 26
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
thought questions about multiturn homopolar generator
Salvador
Sat Sept 03 2016, 07:57PM Print
Salvador Registered Member #54402 Joined: Mon Feb 02 2015, 11:09PM
Hi, It's been a while sine I haven't been here I have done some experimenting and thought some more and before I go on and waste more of my time I just wanted to ask you guys, what do you think , is it possible to make a multiturn homopolar generator that actually works, ok my more specific question would be , would it generate current it I had multiple turns of wire and I made such an arrangement that each turn of the wire would see a magnetic field which points in the same direction , like for example when you have part of a toroid and some coil on it and you arrange the field such that the whole coil sees a field going either inwards to the center or outward from the center.
Or does the generator only work if each loop is connected via each next one by a sliding contact which either is stationary or rotates with a different angular momentum than the loop?
thanks, looking forward for a discussion
Salvador
Tue Oct 18 2016, 09:36AM
anyone ?
maybe rewording my question would be like , imagine a toroidal core like that of a toroidal transformer now the wire is wrapped around also like in the transformer in other words just lets assume i have such a toroidal transformer , and I somehow have managed to split it up in say two or more pieces and each piece has coil on it and the magnetic field is pointing outwards at all points , then I rotate this assembly , would this work as a multiturn homopolar generator ?
1476783402 54402 FT177796 Homopolar B Field
