  • Guests: 52
Elliott (35)
Gratitude (40)
Swraka (37)
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
advice on building a nixie tube calculator
nzoomed
Wed Aug 24 2016, 04:12AM Print
nzoomed Registered Member #54503 Joined: Sun Feb 22 2015, 10:35PM
Im fascinated with Nixie clocks and am looking at doing something a little different by building a calculator using nixie tubes instead of a regular LED segment display or VFD etc.
I was looking at using a single chip module such as a TMS-0103 or the likes.
One question, can this chip easily be adapted to using nixie tubes rather than a segment display?
Im not sure what kind of encoding is used for the digits, and whether or not the outputs could be fed straight into a nixie driver or not.
Thanks for any info
If there are better chips out there im interested to know, i dont want to use a raspberry pi, as thats fairly complex and i have to wait for it to boot.
Could an arduino work perhaps?
TIA
Wed Aug 24 2016, 07:12AM
You need some high volatge transistors to interface between the ICs and nixie tubes, like the widely used MPSA42.
Maybe you can find some inspiration in my nixie tube clock: Link2
nzoomed
Wed Aug 24 2016, 07:25AM
Mads Barnkob wrote ...
Thanks will take a look.
Ive got a whole bunch of 5870 nixie's and plan to do a clock that can fit in a spare 5.25 bay of my computer.
I hope i can make it all fit.
A calculator should be easy with a good single chip module, but as you mention you need high voltage transistors between the IC's and drivers, although i believe the IC's designed as nixie drivers do not need this.
I see some people take shortcuts and only use one driver IC and multiplex it to all the tubes, i dont know what way is the best option, if each nixie is driven, they are supposed to be alot more brighter.
johnf
Thu Aug 25 2016, 06:56PM
You could try the correct TTL chip to drive the tubes 74141N BCD to high voltage decimal drive
nzoomed
Fri Aug 26 2016, 09:01PM
johnf wrote ...
Yes was looking at that, only problem is that the calculator IC i was looking at using is designed to use a multiplexed BCD display.
Hazmatt_(The Underdog)
Fri Aug 26 2016, 09:25PM
just use an arduino... sheesh.
nzoomed
Sun Aug 28 2016, 09:02PM
Im looking at that option, but dont know anything about coding them...
Tue Aug 30 2016, 01:48AM
its all C code. That and use the serial to parallel conversion to make a huge data bus.
You will be using many shift registers, one per tube, and a shift left operation or lookup table conversion to change the bits.
So 0 would still be 0 on the shift register, but if you want to light the digit 1 it becomes binary 2, and 2 is binary 4.. and so on.. since the tubes are segmented you have to make your own conversion.
Or you could use the BCD to decimal converters like mentioned before and cut down on the shift registers, either way it doesn't really matter. The BCD converters would allow you to use one shift register for two BCD and two tubes, the software method is more computer 'sciency'.
