  • Guests: 48
Elliott (35)
Gratitude (40)
Swraka (37)
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
Homemade Triode
RateReducer
Mon Aug 01 2016, 06:13PM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Hi guys,
I built an high vacuum pump system. First experiment - a homemade triode.
Here is a video of the first test:
The triode actually works.
some other experiments will follow cheesey
hen918
Mon Aug 01 2016, 06:36PM
Brilliant! That looks like an awesome setup there.
You could make some really big high current triodes with some glass piping for watercooling. The (very) early modulators for AM radio used a vacuum pump to continuously evacuate the air. The valves (vacuum tubes) would be dismantled periodically for maintenance involving cleaning the electrodes.
RateReducer
Tue Aug 02 2016, 05:12AM
Thanks!
hen918 wrote ...
Wow i did not know that... Sounds really interresting
Maybe i will make a bigger and better constructed triode soon.
Wed Aug 03 2016, 04:56AM
I have some assorted old tubes if you want them to make feed throughs.
They are up to air but the connectors look OK, also even broken they are quite interesting to dismantle for the plates etc.
