  • Guests: 42
LONEOCEANS RSSTC BUILD
wikus
Thu May 12 2016, 09:43PM Print
wikus Registered Member #58198 Joined: Sun Dec 27 2015, 11:15AM
HI ALL
I HAVE BEEN BUILDING A SSTC BASED ON LONEOCEANS RSSTC BUT THE HALF BRIDGE FROM A ONE TESLA .I ALSO ADDED A 2N35 OPTO FOR THE INTERRUPTER.
THE SECONDARY 85MM X 300 MM @ 260KHZ WITH TOP LOAD
I CANT GET IT TO RUN TESTED DRIVER BUT GET A VERY STRANGE SCOPE READING ON THE FEEDBACK OUTPUT OF 1MHZ@3V
HERE IS THE PCB LAYOUT PLEASE CAN SOMEBODY CHECK THIS AND GIVE SOME ADVICE OR TELL ME IF I SKREWED IT UP
THANKS FOR GREAT FORUM
WIKUS
1463089380 58198 FT0 Untitled
Fri May 13 2016, 08:00AM
Hi Wikus
Please edit your thread to not be in all caps.
Part I: Behavior and Conduct
C. Be clear and concise. Do not type ALL IN CAPS, do not use 1337-5p33k, and do not type everything in long run on sentences with no breaks or punctuation because theyre very hard to follow along with and we all dont like them. :) :o ::) ??? :-[ :P ;D :D ;) If you have a problem with spelling, spell-check your posts.
