  • Guests: 43
Running stepper motors without using semiconductors
Mon Mar 14 2016, 09:26PM Print
Most AC and DC motors can be run on the bench, or in the lecture hall, without electronic supporting equipment. At most, a capacitor for some AC types.
I used to think that common stepper motors are an exception. Collected some parts for a driver involving microswitches instead of transistors, and one or more cams on a hand-cranked shaft. Much less flexibly, I bet most scrounged steppers can be demonstrated using low voltage AC with a capacitor for phase shift, as in the seminal Slo-Syn units.
Then realized there's a simpler way to generate the requisite two-phase AC power:
twist the shaft of another common stepper motor.
Made this demo a few years ago. Its 4-wire connecting cable came from the same dead printer, so no wire cutting or soldering was needed.
The slave shaft (worm) runs in either direction, without slipping, if the master (stubby pinion) is turned fast enough.
1457890853 2099 FT175958 Dscn0415
The little generator-motor set turned up last Friday as I prepared for the Saturday hamfest, reported in a different thread. Served as a show-and-tell curio.
Ash Small
Wed Mar 16 2016, 01:34AM
I made up a little board with a couple of double pole, double throw switches for evaluation purposes a few years ago.
Never got around to testing it out, due to a spot of illness. I'll dig it out.
kimbomba
Wed Mar 16 2016, 04:19AM
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
you can use a capacitor to move the phase in one coil and the motor will run, but only at 60 Hz (or the frequency of your mains)
BigBad
Fri Mar 18 2016, 04:36PM
Doesn't this rely on the residual magnetism in the stepper motors?
Some usage situations can zero this out; if that happens it won't self-start.
You're normally better off having one of the motors being a permanent magnet AC motors; that way, provided the currents are kept at sensible levels, the magnets will not degauss and you can always start it.
Sat Mar 19 2016, 09:22AM
One hand turned motor connected to another? typically this works with a larger motor driving a smaller one and is a well known physics demo.
radiotech
Sat Mar 19 2016, 04:38PM
Selsyns transmit rotational position between units. Military used them for years as indicators. However, they have
a strange mode. If the shaft of one unit is held fixed, and the other unit is driving an unbalance mass, i.e. a pointer,
the free shaft unit can be shocked into rotation, electrically or mechanically. This irked the operators of very
large machinery, and electricians were called to correct the situation.
The slo syn motor has a toothed magnetized rotor and are designed as a split phase
slow speed, high torque motor. They will run at a synchronous speed governed, (within
reason) by the line frequency. They also offer a degree of holding torque. The capacitor
has to be in the ballpark of what is called for.
As with much old junk electrics, the oil capacitors may contain pcb oils.
1458405536 2463 FT176005 Slo Syn Patent1
1458405536 2463 FT176005 Slo Syn Patent2
