  • Guests: 93
Elliott (35)
Gratitude (40)
Swraka (37)
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
Help powering a neon-sign transformer (NST)
Sun Feb 14 2016, 10:19AM Print
Registered Member #54664 Joined:
Hi there. I just got a neon-sign transformer, with the following specs:
Primary: 120V 60Hz 420VA
Secondary: 15kV 30mA
...but I'm afraid there's a problem: I'm in Europe, and here line voltage is 220V at 50Hz. The voltage is not an issue since I have a variable transformer; however I don't know how to deal with frequency. I don't want to buy an expensive frequency converter (and I didn't even find one online); I have read that I can power a 60Hz transformer with 50Hz current, but that would increase the amount of current flowing throughout it so I should use a current-limiting resistor on the input. Otherwise, I thought about feeding it with a lower voltage (say about 100V), but I don't know if that would work.
What do you say? What's the best solution to prevent damage to the transformer? Thank you.
Patric
Sun Feb 14 2016, 10:38AM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
100V will do fine, no worries.
Ash Small
Sun Feb 14 2016, 02:26PM
What Patric says, 100V.
Sun Feb 14 2016, 02:27PM
Alright, thank you.
Signification
Tue Feb 16 2016, 11:35AM
Yes, 100V.
And, BTW, I have seen some very good VFD's on EBAY at great prices--you just have to look--some that are very similar or identical were also listed at very high prices. I intend to get one soon.
