  • Guests: 67
RoV IW3IPD (63)
01/13 si2030 (62)
Honeycomb for Structural Purposes.
Thu Feb 04 2016, 12:05AM Print
Ive been figuring on the best way to replace Styrofoam and Balsa wood from my drones.
First, the balsa wood would warp by itself, and of course shred apart in just normal storage. When fiberglassed, it was heavy an flexable.
Second, using a Styrofoam table, the Fiber glass or carbon would peel from the edge, and epoxy wont stick to Depron at all.
So, needing a strong but light material, and having a machine to do the tedious work, I went back to thinking about "I" beams and second moment inertia.
This drove me towards the trusty honeycomb shear web. I couldn't afford the typical material sold on Ebay. So I went at it my self and here are the results.
1454544354 2431 FT0 Hex1
1454544354 2431 FT0 Hex2
1454544354 2431 FT0 Hex3
AndrewM
Fri Mar 04 2016, 12:01AM
You're find that the shear strength of single walled prints is horrendous and your honeycomb is a poor approximation of the real thing.
BUT... there is still some merit here in the sense that you can use this to create large monocoque designs and gain strength that way.
Fri Mar 04 2016, 01:27AM
the real problem is that I cant find a chemical to use on PLA. I don't know if PMMA will do it, I need to test that.
ConKbot of Doom
Fri Mar 04 2016, 02:05AM
Finally got around to fixing my printer after being down for a while, and much to my pleasure the local microcenter has a good selection of filaments. Long story short, PETG filament is pretty awesome stuff, very good inter-layer bonding. Check out some video reviews for an idea of how it behaves.
Link2 as an example
Obviously the Taulman stuff in the video will be top quality but even the cheaper ($24/kg) stuff I picked up is quite strong. Stiff, but with just enough flex to be tough and not have a brittle failure. In a thin sheet (3 layers) its quite flexible and feels pretty strong. Ive had luck with it on a kapton bed as long as you keep the first layer close and the bed around the glass transistion temperature (1st 3 layer 90C, then ease off to 80C for my Flashforge creator X)
As far as gluing, still not as easy as ABS, I'm seeing people suggesting IPS weld-on variants, havent glued any myself.
Eastman (resin OEM) suggests a few different solvents, but most of them qualify as either "The good shit" or "Nasty stuff" depending on your perspective.
MEK, Tetrahydrofuran, cyclohexanone, Methylene Chloride, Ethyl Acetate. IPS weldon #3, and #16 both look heavy on the methylene chloride, with #3 being mostly straight MCL, and #16 having MCL, MEK, and methyl acetate, both with a hint of super-glue for good measure.
BigBad
Fri Mar 04 2016, 02:57PM
Patrick wrote ...
Did you try laminating it, like plywood? Plywood is very dimensionally stable.
I did wonder whether you could get laser cut balsa sheets with hexagonal cutouts, then you could layer them at 60 degrees, obviously haven't tried that, sounds good on paper at the very least. Could well be insanely light, rigid, stable and strong.
