  • Guests: 59
Strange gate drive waveform in my SSTC?
Phil33ts
Tue Dec 22 2015, 01:49PM Print
Phil33ts Registered Member #57473 Joined: Sat Oct 03 2015, 03:21PM
Hey
I have built SSTC:
- NE555 interrupter
- 74HC14 with antenna
- TC4452/TC4451 MOSFET drivers
- GDT
- IRFP460 halfbridge (10 ohm gate resistor)
I didn't started it with mains 230V power because I'm not sure if MOSFETs are correctly driven.
Driver schematic:
Power section schematic:
And here is how the gate drive waveforms looks like when connected to 50V power supply (I've tried also 30 and 70 and they are similiar):
The SSTC is working but it is not okay according to:
My question is: is my gate driving waveform correct (and now, how to improve it)? I havent tried connecting my SSTC to mains because I don't have much MOSFETs and I don't want to blow them.
Thanks in advance!
1450792164 57473 FT0 Schematic Halfbridge
1450792164 57473 FT0 Schematic Driver
1450792164 57473 FT0 Source Gate Waveform
Perezx
Tue Dec 22 2015, 02:52PM
Perezx Registered Member #54263 Joined: Thu Jan 15 2015, 09:54AM
Its almost okay. That double-peak, if you mean it, is probably Miller effect.
Next time try to show V/div and ms/div when showing waveforms
Phil33ts
Tue Dec 22 2015, 03:14PM
Perezx wrote ...
What should I do? Increase gate resistor or not? But well, the most people are using 10 ohm for IRFP460 and it seems okay.
BTW: could it be it also caused by that my secondary has a bit high resonance frequency?
Sigurthr
Wed Dec 23 2015, 03:36AM
Without scale information it's hard to tell but they don't look bad at all. No intense ringing, no major linear region forays or nonsense other than -maybe- a slightly slow rise time. You could try reducing the gate resistor value, as the higher the frequency of drive the more current is required to charge/discharge the gates quickly enough. It certainly doesn't look bad though.
