  • Guests: 65
CT phase shift??
flyboy7777
Sat Dec 19 2015, 12:41PM Print
flyboy7777 Registered Member #58118 Joined: Sat Dec 12 2015, 12:34AM
I'm just curious about this... I have a DRSSTC that I'm in the middle of building, and I noticed something odd about when I tuned the phase lead. It seems that when I finally get the phase lead inductor tuned to the point where I get minimum ringing, the phasing between my primary current and bridge output doesn't really look like it's right at 'zero crossing'. I'm curious about why this would be. I was thinking maybe the difference in burden resistance? I'm using a goodchild 2.5 driver board, and the standard 51ohm internal feedback burden, versus my CT for "current sniffing" on my scope that I have at 10 ohms. Using a full bridge of CM300. Any ideas? I want to make sure I have this thing tweaked just right before I go too crazy on power levels. Right now its only a 170 volt bus, but planning on voltage doubler for 340 volts.
Thanks!
Jonathan
Wolfram
Sat Dec 19 2015, 03:33PM
You get a minimum of ringing on the bridge outputs when zero voltage switching is happening. To get zero voltage switching, you need to switch the bridge before current zero crossing, so that there is some current to commutate the bridge output voltage to the opposite rail during the dead-time. Ideally you want to switch early enough that you get good ZVS, but not much earlier than this. What you're observing makes sense. It is still not established if this is the optimal time to switch in a DRSSTC, but it's the best candidate as far as anybody knows.
flyboy7777
Sat Dec 19 2015, 03:49PM
Interesting. Thank for the reply.
Hydron
Sat Dec 19 2015, 05:25PM
Hydron Registered Member #30656 Joined: Tue Jul 30 2013, 02:40AM
You can get phase shifts in CTs, I've done some frequency sweeps to look at it, an example below:
1450545892 30656 FT174407 Medium Ct 2
loneoceans
Sat Dec 19 2015, 09:01PM
flyboy7777 wrote ...
Thanks!
Jonathan
How did you construct your CT? It is possible that your signal is phase shifted because of the loop formed by the scope probe and and lead especially since it's a high impedance at the scope side. Proper current probes have a BNC right out of the probe.
Goodchild
Tue Dec 22 2015, 04:54AM
Wolfram wrote ...
This type of drive doesn't allow for ZVS due to the lack of dead time between high and low side switches that would normally allow commutation to happen. Rather the reason phase lead is implemented is this type of driver is to "pre-switch" the IGBTs to allow the IGBT to fully turn on or off before the zero current crossing so that the transition happens right at the zero crossing point in an attempt to achieve optimal conditions for ZCS. This phase lead also weeds out all other propagation delays in the drive and feedback that may otherwise cause the IGBT to turn on late.
If you are seeing a slight amount of lead this is normal and exactly what you should see if the lead is set correctly. The LR Burdon network creates a voltage that slightly leads the current in the tank. This lead in turn translates to early transitions in switching of your IGBTs. The turn-off or on should slightly lead the crossing event.
If you are seeing a large amount of lead you may want to look into what loneoceans mentioned as a possible source of phase error.
flyboy7777
Mon Dec 28 2015, 01:22PM
Thanks for the replies. In response to the question about my CT... It's the standard cascaded 1:33:1:33 configuration, with a 10 ohm burden right at the transformer. There's a 3 foot piece of shielded 2 conductor twisted pair Milspec Tefzel wire attached. Terminated to banana plugs, going through a banana-BNC adapter on the o'scope.
I've actually run this coil now, and It's doing 6'+ sparks. I'm pretty pleased with it! cheesey
58
