  • Guests: 52
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
Nixie Clock
RateReducer
Sat Dec 12 2015, 07:38AM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Hi.
I did not post here for quite a long time so i thought i could share my new Nixie Clock.
DSC 1570 Zpsdogosh3a
DSC 1542 Zpsii894wqf
DSC 1543 Zpsbfl6pkpw
DSC 1545 Zps31kqpqjl
I built 2 similar clocks - the one in the first pic just has black sockets.
Nothing special. IN-14 Tubes, Arduino + RTC, NE555 "HV" generator.
Self made double sided PCB (layout and etching)
Regards, Daniel
Sigurthr
Sat Dec 12 2015, 08:00AM
Very nicely done! Board layout looks beautiful!
Dr. H.
Sat Dec 12 2015, 01:50PM
Niice work. Love the fact you didn't opted for LEDs under the tubes (as many do) Looks much more old school this way
Cheers smile
Sat Dec 12 2015, 05:49PM
Dr. H. wrote ...
Cheers smile
I don't understand, what do others do with LEDs ?
RateReducer
Sat Dec 12 2015, 06:35PM
Thanks! cheesey
Some people use leds to illuminate the bottom of the Nixie tube. But i don't like this at all.
A few days ago i ordered some Z566M tubes. Those are coated with a red varnish which can be removed easily as described on this german website: Link2
What do you guys think, should i remove the varnish or should i keep it??
TwirlyWhirly555
Sat Dec 12 2015, 07:09PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Very Nice : D .
I personally prefer clear tubes , its what I'm using in my nixie clock , Just depends on what you like the look of
Sat Dec 12 2015, 08:32PM
RateReducer, since it is easier to remove than to re-apply the red varnish
maybe build it red and if you do not like it then take the irreversible step.
Electra
Sat Dec 12 2015, 09:48PM
Love anything with Nixie's too, I don't think people will look at l.e.d's in that manner in another 50 years time. Really nice build also by the way.
The red varnish is there to give better contrast isn't it? So easier to read in bright light, if its not badly scratched or pealing off, see how it looks first.
You can light one up as a test if your worried about not be able to remove it once their fixed to the board.
How does it keep its time? Is it just relying on a register/counter that crystal clocked, or does it sync to some external time standard?
RateReducer
Sun Dec 13 2015, 10:40AM
Thanks, TwirlyWhirly555. I also think clear tubes look better (on the pictures). I have not seen any caoted tubes in real life jet. Maybe they look good ^^
Sulaiman, thats the way to go! Thanks!
I will find out ^^
i use a RTC (real time clock). That´s a temperature compensated clock module with a battery also known as hardware clock.
RateReducer
Wed Dec 16 2015, 10:36PM
Today i received my Z566M tubes smile
Pics:
The left tube is a IN-14.
Seems that the contrast of the red tube is better.
