  • Guests: 38
kywalda (63)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Correct GDT core?
nzoomed
Thu Oct 29 2015, 05:48AM Print
nzoomed Registered Member #54503 Joined: Sun Feb 22 2015, 10:35PM
I couldnt find the correct type 77 fair rite cores available, mouser says they are discontinued.
I was advised by loneoceans that these work well.
Has anyone used this core before?
It looks a tad too small i thought, its not as flat looking as i would have expected.
TIA
Goodchild
Thu Oct 29 2015, 01:17PM
nzoomed,
When looking for toroids for your GDT core you will want to consider a couple key parameters. Lets start by looking at the universal transformer EMF equation:
79308cfb2a6645e746cb2346be0bfd94
This equation is technically for sinwave inputs and outputs, but it gives an okay approximation for GDTs with a square drive.
f - being your frequency of operation
N - number of turns on the core (for the winding of interest)
a- cross sectional area of core
Bpk - the peak saturating flux density your core will support
Erms - being the RMS voltage the core will support at the given frequency
If you rearrange the equation and play with it a bit you will notice a couple of interesting things.
1. For any given transformer configuration (ie fixed - core Bpk, turns, and a) you will get a fixed volt/second coefficient that the transformer will be able to handle. Exceeding the V/S ratio and by proxy Bpk the transformer will saturate.
2. Increasing turns or cross-sectional area with decrease Bpk. Bpk is flux density or flux per unit area.
Now on to the fun part selecting your GDT core. First select a material. T65 if a good choice I also use T65 cores for a lot of the things I do. Look for your self at the datasheet:
http://de.tdk.eu/blob/187202/download/4/pdf-t65.pdf
It has a saturating flux density (Bpk) of 0.46T at 25*C. The initial permeability is a little less critical in this application but something in the range of 3000u to 6000u will work fine.
TDK and other companies have lots of flavors of ferrite and I encourage you to shop around.
Go shop around for a larger core with T65 materiel (Digikey also sells a lot of them). Once you select a core plug it's specs into the above equation and you will be able to see if it will work in your application.
I hope this helps!
nzoomed
Thu Oct 29 2015, 09:33PM
Goodchild wrote ...
nzoomed,
I hope this helps!
OK, so i do need a larger core? I thought this one looked small, but loneoceans said that this one has worked well for him.
This looks perhaps a better option and is much larger:
Although it appears discontinued and seems to be replaced with 78 material like this:
I dont know what type of core the 5000:1 ones are that easternvoltage research sells, but thats probably close to what im after.
Im using the UD 2.7, which i believe puts out around 20V into the primary.
I tried some calculations, but my Erms comes out as 498080587.848
Which is obviously ridiculous!
Is the frequency in the equation supposed to be written in Hz or KHz?
Cross section of the core is 256mm2 and my coil will be running at 68000Hz
Transformer has 14 turns on the primary, so these are the figures i used in my calculation.
hen918
Fri Oct 30 2015, 04:16PM
nzoomed wrote ...
you will need everything in SI base units. i.e. meters squared and Hz
nzoomed
Fri Oct 30 2015, 08:49PM
hen918 wrote ...
nzoomed wrote ...
OK, so thats where ive gone wrong then! lol
Goodchild
Sat Oct 31 2015, 06:48AM
hen918 is correct you need to use all SI base units in any kind of electrical engineering.
Those cores you linked are crazy expensive, you can go much smaller and cheaper.
Here is an example, take this core on digikey: Link2
It's T37 ferrite, Bpk of .38T at 25C.
It has a cross sectional area of 51.26mm^2 or 5.226e-5m^2 So plug these numbers into the formula:
4.44 * 68e3Hz * 14 * 5.226e-5m^2 * 0.38T = ~84V
This as you can see is a rather overbuilt configuration. The UD typically puts out 24V so this would work fine. Remember though this case is for 25*C the saturation changes with temperature and it's up to you as the engineer to plan for the worst case your design would see in operation.
Hope this helps.
EDIT for further reading on magnetics check out this page:
nzoomed
Sat Oct 31 2015, 10:49AM
Goodchild wrote ...
Hope this helps.
Thanks for that info, however according to the datasheet, its diameter is only 25mm, which is smaller than my toroid i currently have which is around 41mm.
I tried winding my cat5 around it today, and i cant even get anywhere near my 14 turns on it, so i think i do need a larger toroid.
Goodchild
Sat Oct 31 2015, 08:45PM
I only picked that core as an example. You will need to shop around to find what work for you. My goal was only to give you the means to correctly select a core for your use.
nzoomed
Sat Oct 31 2015, 10:04PM
Goodchild wrote ...
OK, i understand now where you are coming at.
But the only problem is that all the large cores are rather expensive anyway, so i was just going to go with one of those larger cores.
Anyway, since ive ordered everything i thought i needed from mouser, its going to cost much more to order another single toroid from them, since its going to cost me at least $50 including shipping
Im limited pretty much to what RS can supply me.
Im interested how you say i can go much smaller and cheaper.
I cant really go much smaller if im trying to turn 14 turns of cat 5 on the core.
It seems most people are using them this size for their GDT also.
The weird thing is that Mouser was showing this as discontinued the other day, but when searching by size and dimensions, i find the very toroid listed with the same part number Link2
Its my fault for not checking the dimensions i guess, but i thought the part number for my toroid was a larger one like this.
Lesson learned.
Goodchild
Sun Nov 01 2015, 05:29PM
nzoomed wrote ...
Goodchild wrote ...
Lesson learned.
It wouldn't be 50 more dollars. a 56mm torrid on Digikey is $8.
Also you don't necessary need 14 turns, the larger the cross section the less turns you need.
