  • Guests: 62
Inducktion (32)
Standa (31)
nabzim (33)
12/21 Inducktion (32)
12/21 Standa (31)
12/21 nabzim (33)
The effect of Reynolds number on a 2D incompressible viscous flow around a cylinder
Russ Edmonds
Thu Oct 15 2015, 05:46PM Print
Russ Edmonds Registered Member #46264 Joined: Sun May 11 2014, 05:27PM
The flow field is color coded according to velocity. A Python script using the Lattice Boltzmann method was used to solve for the flow. Fluid viscosity was varied to realize the different Reynolds numbers. The Python script can be downloaded from
