  • Guests: 36
Epoxy Coating Tutorial Video
Phillip Slawinski
Sat Oct 10 2015, 11:26PM Print
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Hey all -- I put up a video on the Youtubes detailing my procedure for coating secondary coils with epoxy. Maybe somebody will find this handy.
Kizmo
Sun Oct 11 2015, 08:01AM
Nice tutorial
Some things i have found out while doing my coils:
Epoxies are different. These days i prefer epoxies that are designed for coating such as Gurit SP 320. General purpose epoxies that are meant for laminating or as adhesive are much thicker. SP 320 is very viscous compared to these general purpose epoxies and does not need vacuum degassing or tedious bubble hunting after it has been applied.
Mixing pot size vs pot life is a thing, guys at composite shops call this as surface area vs volume ratio. You want it to be as large as possible to prevent thermal runaway. Initial coat should be very light, leaving tops of the wires exposed. This way there wont be nearly as many bubbles when the air escapes from behind the windings. Heating the initial coat may make bubble problem even worse as the air trapped behind windings expand from heat.
You can never get it truly perfect, but you can certainly mess with it too much. I have had random bugs stuck on my coils every now and then. For spreading i used cheap disposable foam brushes that i didnt bother to clean after use. And tiny wooden stick to pop any bubbles.
Overall its hard to imagine why people still use polyurethane for tesla coils, epoxy is so much nicer and doesnt smell nearly as toxic :)
Phillip Slawinski
Sun Oct 11 2015, 01:31PM
Thanks for the additional tips.
Kizmo wrote ...
So my experience with foam brushes (and it only applies to the kind of epoxy you can get from a hardware store) is that the put bubbles into the finish. I suppose if you're using a much thinner epoxy then this wouldn't be a problem.
I also wonder why people still use poly to coat their coils. I only coated one coil years ago with poly, and then I went to epoxy.
jdub1581hv
Sun Oct 11 2015, 06:46PM
jdub1581hv Registered Member #55219 Joined: Tue Jun 09 2015, 11:21PM
Have you guys tried using a Casting Resin or is Epoxy the preferred product?
I have not used this on a coil, but have used it quite a bit, and used to work for this company as well as a fabricator(many moons ago).
Clear-Lite Resin
I would think application would be almost the same, if not quite a bit easier.. Add catalyst mix and pour.
It's virtually indestructible as well, where epoxy would be more shatter prone on impact.
I'm getting ready to build my 2nd coil, 6" x 18" #28awg, and have been thinking about what to use, My head keeps thinking about this, but I'm fairly new to TC's so was wondering what you thought. ?
nzoomed
Sun Oct 11 2015, 09:53PM
nzoomed Registered Member #54503 Joined: Sun Feb 22 2015, 10:35PM
Phillip Slawinski wrote ...
Kizmo wrote ...
Are there any issues with polyurethane?
I used it because the sort I used is moisture curing, which means any moisture is absorbed when it dries which i thought would be a good advantage to the coil.
Epoxy takes longer to dry, but is harder and i guess that could offer more protection to the coil?
Phillip Slawinski
Mon Oct 12 2015, 01:05PM
I've never used any of the casting resin, but I think it might be worth a try.
Issues with polyurethane? I don't know how it stacks up head to head against epoxy for equal coating thicknesses. I do know that the epoxy is quite a bit easier to get a thick coat with, which is one of the primary reasons why I use it. In three coats I was able to build up about 0.0625 inches of epoxy on the form in the video. I've had coils in the past that flashed over end to end with no signs of visible damage, but maybe some could say the same for poly...?
I'm not sure about the epoxy taking longer to cure. Curing time really depends on temperature with the epoxy, and the warmer it is, the faster it will cure. I find that typical curing time is in the range of 4-8hrs.
Kizmo
Mon Oct 12 2015, 02:24PM
Thing i like about epoxy is the wide range of hardeners. It takes out the guess work and worthless waiting. For example for the SP320 I prefer is available with different hardeners from 30 minutes to 10 hours. And thickness is big thing, when i coated my large space wound secondary i dumped nearly 1kg of epoxy on it in one shot. It would have taken ridiculously many coats of polyurethane to get same thickness.
1444659823 599 FT173551 Z8sdj9s
1444659823 599 FT173551 7lcx1pl
No several coats, no hours of waiting, no sanding, nothing. Just dump, spread, and done.
nzoomed
Tue Oct 13 2015, 01:07AM
The polyurethane I was using was designed for use on wooden floors.
It gives a real thick coat on the first coat, and would have almost been enough, giving it one more coat and its given it a really good build!
The brand i used was uroxsys moisture curing polyurethane, but thats a New Zealand brand, you might be able to find a similar product no doubt, but you want to look for a good quality one designed for floors. This stuff was touch dry in 20mins to less than an hour.
Patric
Tue Oct 13 2015, 08:33AM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
nzoomed wrote ...
Me too I use polyurethane, never had problems.
Kizmo
Tue Oct 13 2015, 10:47AM
It's inconvenience more than actual problem.
