  • Guests: 50
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Roller Blades on Ice...
Slava
Wed Oct 07 2015, 07:19PM Print
Slava Registered Member #518 Joined: Tue Feb 13 2007, 05:20AM
I am trying to make metal wheels for my roller blades so I can use them on ice...
I designed the parts in SketchUp 3D CAD, but I am having trouble finding someone who can machine them...
I tried eMachineShop .com but I was unable to import my model into the software they provide.
Can anyone help?
001
Alex Yuan
Sat Oct 10 2015, 06:11AM
Alex  Yuan Registered Member #9614 Joined: Mon Jan 14 2013, 10:00PM
What are the dimensions? I can check what we have. Though I know Kizmox can do some very nice metalworking.
omegalabs
Sat Oct 10 2015, 04:41PM
omegalabs Registered Member #1521 Joined: Thu Jun 05 2008, 10:46AM
Find someone with a lathe near you. You should make a sheet with all of the dimensions on it, including the material type and the tolerances.
I could do something like that, but I think I'm too far from you :)
Slava
Sun Oct 11 2015, 01:53AM
How much would it cost to make 8 wheels? The wheel diameter is 3" ...
Material: 6061 or 70.. aluminum
hen918
Sun Oct 11 2015, 09:55AM
Slava wrote ...
You might want something harder than aluminium...
Slava
Tue Oct 13 2015, 06:53PM
I was told to use 7075 aluminum or steel. But steel isn't easy to machine...
2 feet x 3" diam rod costs $210
How much would you charge me to make it?
8 Wheels total
Dim
omegalabs
Thu Oct 15 2015, 10:12PM
Sorry, but I don't understand this picture. There is an actual diameter with 22.5mm, then 40mm and then 20mm. What's the 20mm dia?
You need to make your plan more understandable. I uploaded an example, how I draw a similar project, silicone rubber coated rollers.
Your wheels have a pretty easy form, a local machinist would do all the 8, a maximum of 100$ for me if I needed something like these.
I don't really know the exact function of these, but if you want some more precise work (like you want to place a ball bearing inside of that hole for example) prices can go higher.
I also don't recommend any kind of aluminum here. I'm not even sure steel is good for this, as the edge is pretty weak with its 6mm thickness and can bend easily.
1444947148 1521 FT173528 Unnamed
This is why the cutters are made of fast steel or tungsten carbide.
Slava
Fri Oct 16 2015, 02:53PM
2
SIDE
TOP
TOP2
STL File...
SketchUp File...
SketchUp File with measurements...
Slava
Fri Oct 16 2015, 10:49PM
3d printing a prototype. ..
1889848633
Slava
Sat Oct 17 2015, 03:57PM
3D printed some wheels last night...
001
