  • Guests: 47
R as a function of temp in NTC material
Bored Chemist
Sat Nov 04 2006, 12:09AM
"I wanted to know the resistance of that thing at high temperature so I applied heat to it from an external source. To measure resistance I passed a constant 100mA through it and recorded the voltage. No matter how much heat I applied to the thing (I was using a propane torch), the resistance measurement just kept going down."
Kept going down with time, voltage, current; phase of the moon?
How might this thing be expected to know if the heating was external or internal?
What we need is a set of V vs I plots; preferably at well defined T otherwise we are left filling in for guesswork.
If all else fails you can make some "reasonable" assumptions for the temperature/ resistance curve based on known physics.
kell
Sat Nov 04 2006, 07:52PM
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
Drat! I forgot to account for moon-phase shifting!
Sun Nov 05 2006, 11:55AM
You also forgot to account for the internal resistance of the power supply, ammeter, wires and connectors. (Next time try measuring the voltage across the spring while the current is flowing, rather than assuming it's 12V.)
