  • Guests: 78
What is the effect of increasing the voltage supplied to a Tesla coil on its electric field
TeslaIsBae
Sat Sept 05 2015, 06:04AM Print
TeslaIsBae Registered Member #55171 Joined: Fri Jun 05 2015, 06:44AM
Hello!
I would like to know what effect increasing or decreasing the input (supplied) voltage has on a Tesla coil, in particular its electric field and the length of the sparks. I found that the sparks increase with the wattage of a Tesla coil, therefore I would think that the electric field also increases. For example, when my Tesla coil is powered by 230V and I change that to 300V what will happen?
In the case that the supplied voltage has no effect on the electric field, what does change the radius of the field? I know that the torus has a big effect on it, but does the frequency of the Tesla coil determine the size of the electric field?
Thank you in advance! :)
Ash Small
Sat Sept 05 2015, 09:10AM
The simple answer goes something like this:
The voltage on the topload determines the field.
While you need a high voltage on the topload for streamers this isn't the only factor. Frequency and current also play a part, as more current in the streamer causes more heating of the air, making it easier to ionise on the next cycle.
TeslaIsBae
Sat Sept 05 2015, 12:00PM
Could you please give me the more complex answer. I hope I can handle it.
Antonio
Sat Sept 05 2015, 12:59PM
Tesla coils are essentially linear devices. Supposing that nothing breaks down, if you increase the input voltage the output voltage and the electric field around it increase in the same proportion. Assuming that streamer length is proportional to the input power, it is proportional to the square of the input voltage. A possible problem is that if you use at the input a transformer designed for 230 V and tries to power it with 300 V, its core may saturate and the output will not increase in the same proportion, if the transformer survives the stress.
TeslaIsBae
Sun Sept 06 2015, 10:30AM
That's perfect, thank you.
