  • Guests: 52
New secondary less than 20 inches
crashstudio
Fri Aug 28 2015, 02:25PM Print
crashstudio Registered Member #54484 Joined: Sun Feb 15 2015, 06:18PM
I just wound my new secondary with 26 awg and by the time I got to the end of the role the coil measured 19 1/4 inches. Will this be enough to effect performance?
Coil form is 4" pvc
Power supply 15kv 120ma
Toroid 4" x 17"
MMC - multiple taps up to 34nf
Fri Aug 28 2015, 03:31PM
your height/diameter (H/D) is 19.25/4 = 4.81
which is high but should work well.
Fri Aug 28 2015, 06:12PM
That's right if coil form OD is 4 inches, which matches nominal 3½ pipe size.
If Crash used nominal 4 inch pipe, then the OD is 4.50 inches and H/D is 4.28.
Hazmatt_(The Underdog)
Fri Aug 28 2015, 10:47PM
You're going to be fine.
I have a similar problem, my primary ended up short, so its affected all my calculations and has upset the H/D of the secondary. BUT, as long as it is resonant and tuned you'll be fine.
I'll put it this way, my pri. is so short, I've had to resort to using 18 AWG wire for the secondary coil, at 20" winding length, and it works fine. If you're not that far off, don't worry.
crashstudio
Fri Aug 28 2015, 10:56PM
Cool thank you! I didn't think it would matter, just wanted to be sure before I invest more time into finishing it.
Fri Aug 28 2015, 11:56PM
Just a note though, you probably won't be able to run at full power, there will probably be a lot of primary strikes at 75% power.
I'm building a 15kv/60mA system, and my guesstimate is 5 feet of arc at full power, you would be in the 8 foot region, so it will probably eat itself full open.
