  • Guests: 57
01/12 RoV IW3IPD (63)
MOT winding ratio?
GammaRay
Thu Aug 27 2015, 08:37PM Print
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
I checked the archives for this answer. If it is there, I didn't find it. Maybe someone can direct me to it.
Question: What is the primary to secondary winding ratio for a standard MOT?
Thanks in advance.
Dr. Slack
Thu Aug 27 2015, 08:52PM
The output is around 2kV, often a tad more, 2.1ish. Depending on which side of the pond you're on, the input is 110v or 230v. You hit the divide key on your calculator.
Blackcurrant
Sat Aug 29 2015, 03:35PM
Here are some old notes for a MOT that I used in a power supply.
for a UK MOT 240Vrms input
LCR meter used tested at 120Hz
Pri 1.3ohm 214.2mH Q14.2
Sec 68ohm 16.77H Q26.1
ratio is about 8.85
jdub1581hv
Sun Aug 30 2015, 01:50PM
jdub1581hv Registered Member #55219 Joined: Tue Jun 09 2015, 11:21PM
Roughly 1v per turn on the secondary (for 120v)
GammaRay
Tue Sept 01 2015, 02:57PM
Thanks, much appreciated.
