  • Guests: 75
01/12 RoV IW3IPD (63)
GZ 24 Potential transformer
zippotix
Tue Aug 18 2015, 11:07PM Print
zippotix Registered Member #5208 Joined: Thu Jun 07 2012, 06:12PM
Hello guys, is GZ 24 potential transformer good as a HV supply? Link2,24_eng.pdf . Im planning to use it as a general purpose arc machine and maybe to drive a TC.
GrantX
Thu Aug 20 2015, 04:20AM
Looks like it would be fine. From the specs it seems to be either 15 or 20kV for the HV coil, 100-110V on the low side, and it can handle 400/600VA max continuously (similar size to a big NST). Since there's no inherent current limiting it will require a ballast, such as a 400 or 600W lighting ballast. Of course, the transformer should handle a couple of kilowatts for several minutes, but it's hard to tell how hot the coils are underneath all the epoxy, so it's best to stay safe.
