  • Guests: 38
Vacuum experiments
Wed Aug 12 2015, 05:02AM Print
"In high-voltage types like transmitting and x-ray tubes fast stray electrons may hit the mirror and evaporate sufficient getter material to cause a gas discharge followed by a short circuit and destruction of the tube."
Heh.. No wonder even in pulsed mode my 5642s were expiring.
I did read with interest that magnesium (Mg) being a light metal can be used as a getter if sensible precautions are taken such as a glass shield around the getter with a small gap to let stray gases in.
This could be useful to the DIY Nixies folk as this is a real issue in rebuilt tubes.
Also found Link2
macona
Fri Aug 21 2015, 05:58AM
macona Registered Member #3272 Joined: Mon Oct 04 2010, 11:40PM
You could probably cut up some neon sign electrodes, the insides of the electrodes are coated in getter material from what I understand.
BigBad
Fri Aug 21 2015, 12:56PM
Dunno whether boron would work, it's good at that kind of thing.
Sat Aug 22 2015, 03:26AM
Possibly.
An intriguing titbit of information is that Mg was also used in the very earliest radio valves with would match up with the WW2 era British ones emitting X-rays under pulsed reverse bias.
