  • Guests: 33
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
Induction Heater Questions
knuckles
Fri Aug 07 2015, 01:47PM Print
knuckles Registered Member #55241 Joined: Thu Jun 11 2015, 08:33PM
Hi all,
I do a number of small scale castings of keys for musical instruments (flutes/clarinets). These are made out of brass, bronze, nickel silver (a.k.a. german silver) and sterling silver. The critical thing here is that these are non-ferrous. Currently I use a homemade gas furnace to metal the metal in a silicon carbide crucible which has a hole in the bottom which is plugged by a carbon rod. When the metal is molten, the rod is lifted slightly and the metal flows into the casting flask. This system works well but is noisy and has to be done outside which makes it weather dependent. As I’m based in the rainy north of England this is not ideal.
Having done a bit of reading up, I’m considering building an induction heater to perform the same process using a similar design to IamSmooth’s or Uzzors (thanks to both for the great info). There are a few things I’d like to know before spending lots of time and effort on it though.
Number 1 - Is it feasible, given the following limitations?
- Desire to fully melt small amounts (300-400g) of different non-ferrous metals. The metal would initially be in the form of lots of small, individual, irregularly shaped pieces placed inside the crucible.
- Access only to UK single phase supplies of 240Vac, 50Hz, protected by 16A fuse or breaker. i.e. no 3-phase supply. I could use a 32A fuse in the distribution board if really required but I would prefer to be able to plug it in to a standard wall socket.
Number 2 – Would it require lots of tuning for each different metal or even for each individual load of the same metal? (eg. If I want to do 3 crucibles of brass in a day, will I have to tune for each load?). Having read about IamSmooth’s and Uzzors PLL controllers, I note that some tuning is still required. Is this just tweaking a pot for a few seconds or is it minutes of fine adjustment of different things?
Metal Melting Point
(oC) (oF)
Brass/Bronze 930 1710
Nickel Silver 1110 2030
Sterling Silver 893 1640
Thanks in advance to any replies.
The Ideanator
Wed Aug 26 2015, 07:48AM
The Ideanator Registered Member #54599 Joined: Sat Mar 07 2015, 06:09AM
If you haven't already found the answers, #1: yes, #2: no.
To be very brief, induction heating basically works by generating large currents in whatever conductive material happens to be in the sweet spot of the magnetic field. It's basically what happens when you stick a wire in an outlet (or would, in the US, UK plugs are far less prone to such stupidity). The amount of material will definitely affect heating times and a 300-400g melt will take a while with the amount of power you can supply. You will definitely need to make your machine more sturdy, like running the water supply from the tap which will take away pretty much all the waste heat no matter what you build.
knuckles
Wed Aug 26 2015, 07:50PM
Thanks for the reply. I'd like a bit more info on the tuning from anyone who has practical experience of it. How easy is this - would i have to set up the scope for every melt and adjust pots or just stick the loaded crucicble inside the work coil and let the PLL do the rest?
Also, would you recommend series or parallel tank for this application?
The Ideanator
Wed Aug 26 2015, 09:21PM
I haven't built one yet so my knowledge is limited to some of the theory. It seems to me that the use of a scope in many builds is to monitor how well the PLL is tracking in the prototyping stage since commercial units don't provide that kind of info.
As for the tank design, it's specific to the caps you buy. You'll have to optimize, but (ideal) capacitor math is comparatively simple.
