  • Guests: 42
CRT ocilloscope issue
Wed Aug 12 2015, 04:38AM
Yes. Use the scope you just repaired to test the caps you took out with a frequency generator and graph the voltage drop with increasing frequency smile
the circuit you want is generator---known R---SP-+Capacitor--Gnd
Please make sure the capacitor is discharged before testing, I usually short them for 1 hour now after blowing a meter's fuse from a "discharged" photoflash which had recovered over 70V.
see Link2
BigBad
Sun Aug 16 2015, 01:20AM
Yay. A burnt out resistor huh? I would have thought that that was a rarer type failure. Good going.
brandon3055 wrote ...
I did remove and test a few of the caps because I know they tend to dry out after a while but the few a measured seemed fine although the values I measured on a few of them were a fair bit higher then the rated values. The 47uf caps read about 52uf but I just assumed the manufacturing tolerances were higher when they were made. Or could that be a sign of failure?
No, a lot of caps are quite wide specced, like 20% or something. That's well within spec.
